Home > Td5 > TD5 Not startin!
Page 2 of 2 <12
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Agree with the crank sensor. If you can get hold of a nanocomto see if its reading crank speed would be ideal
Post #869257 23rd Nov 2020 9:50pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
A while ago I forgot to connect the crank sensor after I replaced the clutch. It didn't throw fault codes, but I did get a negative crank speed IIRC.
If you check/replace it, than mind that there's possibly a spacer between the cps and the gearbox housing.
https://www.lrworkshop.com/diagrams/land-r...rs_53229#6
J Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #869294 24th Nov 2020 8:32am
JohnPaynter
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
installed a new crank position sensor,
no start still but im more and more sure it is the issue as there seems to be no fuel getting to the engine but fuel system is fine
i have checked injectors and glow plugs with nanocom and all work
engine idle speed on nanocom reads -939?
also does anyone know what MIL lamp is
i had a few faults 10,1 10,3 10,4 10,5 14,1 14,3 14,4 and 14,5
mostly abs and air conditioning which im pretty sure the car doesnt have, definite on the air con side of things
but to further my certainty that cps is the issue on of the faults said something to do with the tachometer, which if im right links to rpm, and no rpm when cranking is a sign of a cps issue
appreciate any help
Sad
Post #870984 2nd Dec 2020 8:08pm
LandymanStefan
My td5 wouldn’t start earlier in the year.
Changed crank sensor - no luck
Saw the crank sensor wiring was damaged, got Martin on here to make me a stand alone loom from the crank sensor to the ecu - no luck
Bought a nanocom, saw it wasn’t seeing a crank speed when turning over... only thing left was the ecu. Bought an ecu on eBay - problem solved.
Post #870994 2nd Dec 2020 8:31pm
JohnPaynter
ok
i think the next thing to do is check cps wiring
is there any easy way to check the wiring?
it didnt look too dodgy to me but this thing sat on a site for years so
Post #871076 3rd Dec 2020 9:09am
WRLondon
England 2000 Defender 110 Td5 Adventure Corris Grey
signed up just to say i had a similar issue with a misfire, gave the injector harness a wiggle and it came and went, then found out there’s a plug that’s vertical on the cylinder head, closest corner to front right hand headlight (uk drivers side), inlet manifold side, that was loose, just needed pushing back in!
Post #871351 4th Dec 2020 8:54pm
JohnPaynter
Ok thanks ill have a look at that👍
Post #871414 5th Dec 2020 11:07am
Page 2 of 2 <12
