Home > Maintenance & Modifications > Anyone bought bilstein b6 dampers recently? Where from?
mcma1
Anyone recently bought a set of these, front and rear? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #858144 25th Sep 2020 7:30pm
Stacey007
Hello
I bought them from here around 12 months ago?
https://defenderupgrades.co.uk/?s=b6&p...mp;ixwps=1
Along with unrated ARB and poly bush kit all round
Post #858164 25th Sep 2020 9:45pm
rallysteve
Paddock spares was the cheapest last time i looked.
Post #858176 26th Sep 2020 6:01am
mcma1
Stacey007 wrote:
Hello
Did you get the front ARB from Gareth? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #858392 27th Sep 2020 11:55am
Stacey007
Yes the uprated one he recommended.
Post #859578 3rd Oct 2020 2:03pm
Naks
Chaps, I'm looking to get new shocks for my Defender, and many people recommend Bilsteins.
While looking at prices online, I found two different B6s: the 24-065290 and the 24-002530 (just using the rears as an example).
https://www.autodoc.co.uk/bilstein/1043832
https://www.autodoc.co.uk/bilstein/1043491
Does anyone know what the differences are between these two shocks?
Also, in the item descriptions, I see there's a 'Parameter' line item - what does this mean, as the parameters are different for the two different shocks?
Thanks very much! --
Post #869087 23rd Nov 2020 7:04am
I can't find anywhere that actually says what 'parameter' means. The additional cost of the 065290 and the figures attached to the 'parameter' suggests that it's a heavier duty version, though. It also appears that the top eye of that model has a factory fitted bush and sleeve rather than the loose bushes supplied with the 002530.
The Bilstein website and those of its' resellers are frustrating as they lack any sort of detail. Darren
Post #869098 23rd Nov 2020 8:59am
Naks
Yeah, I also had the same thought about the parameters and the significance, but it would be nice to get confirmation.
The prices are also vastly different (from two different suppliers):
24002530 B6 BILSTEIN R2,944.00
24065290 B6 OFF-ROAD BILSTEIN R 4,662.10 --
Post #869100 23rd Nov 2020 9:06am
Roy5695
Personally having fitted the Bilsteins to mine and Fox's to somebody elses vehicle, id choose the Fox's all day long, they seem to be much better engineered and put together.
Just my little input. I know the Fox's are in general more expensive but i believe there to be a good reason behind this! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #869284 24th Nov 2020 3:36am
Co1
Agree with Roy. Have had both and if is comfort you are after the fox is defiantly worth the extra cash.
Post #869287 24th Nov 2020 6:09am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
You make me want to swap my bilstein for fox's now Whistle
Post #869300 24th Nov 2020 8:53am
Naks
got the answer on another forum:
Quote:
9 hours ago, oneandtwo said:
24-065290 are for 1998 onwards rear axle with mounting cups on the axle bracket, 24-002530 are for pre 1998.
B6 along with a 25mm rear anti roll bar transformed my 90 on road.
Post #869306 24th Nov 2020 9:18am
Naks
thanks for the advice, which model of Fox shocks for longer-travel when off-roading? I don't carry much load, so heady-load is not a requirement for me.
Someone else swears by Koni Raids - what do you think? --
Post #869308 24th Nov 2020 9:25am
Interesting! All of the sites I looked at had both models listed for my 2013 110, for example. Darren
Post #869311 24th Nov 2020 9:44am
cold
Co1 - hope you dont mind me asking but you are close to me, who fitted/supplied your Fox shocks?
Post #869313 24th Nov 2020 9:57am
