![]() | Home > My Defender > Puma to LT1/8L90 Restomod |
I think that only makes sense if you're starting with a TD5. If you're starting point is a Puma then there's no point back dating it to a TD5 when something like the M57 is available. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2941 ![]() ![]() |
The go to LS variant is the 430hp with plenty of support and kits ready to go. My plan on my current swap is get something dependable and cut no corners, that's what eats up the ££££. Then add the supercharger when i have run out of ideas. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
mrfirepro Member Since: 07 Nov 2020 Location: kent Posts: 233 ![]() ![]() ![]() |
Hi Andy,
Was looking at the LS376/525 as on the surface seems like a little more bang for your buck. I am assuming all LS3 engines are the same in all other respects. Whats your advice on the best suppliers I should look at? |
The cam in the 480 and 525 is designed for high revs and from the research I did they can be a pain to keep running in the defender, cutting out etc. I just used Partsworld performance in the UK for the engine, front accessory kit etc as they have them in stock but the gearbox 6L80E had to come from PCS in the states. They basically have developed a transmission map which Twisted etc now use. The PCS harness takes care connecting up the gear selector etc and then you have the GM loom/ecu which also taps into the dash. After that its really just what LT230 adaptor you will need depending on the transmission and prop shafts and thats you connected to the axles. They can over heat so on this one I have ordered the larger twin fan radiator and then the 2 smaller oil coolers, one for the trans and one for the engine. I will keep my thread up to date as there are a lot of guys keen on learning more about the install. Personally I want it for floating around, towing the jet skis, one arm out the window and some tunes on the radio which is why i go auto Andy
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 871 ![]() ![]() |
Well that's just plane wrong I'm afraid. |
300hp from a n/a 4.6 RV8 is not likely cheap or easy. Plenty might claim this, only to see more like 26-280 on a dyno IMO. although that would still make a Defender fly. |
Cheap and common in the UK.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
How are you going to resto mod something that isn't old enough??? Anyhooo LS sounds like an awesome swap. Although I honestly don't think 525hp would be all that usable in a 90 if I'm honest. And certainly not on UK roads. Happy to be proven wrong. I've got an LS V8 in a Camaro. And in a lower state of tune. It is arguably too quick for UK roads. But at least the Camaro is stable and capable at high speeds. Which I doubt would ever be true for a SWB Defender. LS swaps also seem to be hugely expensive to achieve. And I'd think to make it fully usable, you'd need to upgrade everything. Although I see little point in ICE or interior upgrades. NVH will always be ![]() No amount of £££££££ will solve this fundamental bit of design. Plus leather pimped up seats just look gash and completely tastless in a Defender. For me, the biggest issue with the LS is gearbox choice. There are options for Automatics, but these are just boring IMO and totally blunt the fun factor of such a setup. A manual is where it is at. But I've never really seen anything that works. Not saying it isn't out there.Marks Adaptors do an R380 to LS adaptor. But I should think it the R380 has a life span of mins with such an engine. If you end up changing the axles, gearbox, transfer box, engine, suspension etc etc. You have to ask, how much Land Rover is actually left. I would also suspect strictly speaking you would also likely end up on a Q plate. As the vehicle would loose it's ID and need an IVA. However, if you do know of a good solution to running a manual box on the LS and retaining the LT230. I'd love to know. |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Fun police alert
![]() Personally I would stay away from an LS in a 90 unless it is a pure competition/HC off roader setup. One of your main issues will be rear prop shaft length depending gearbox- transferbox setup and I am not sure the high HP will suit the 90. I got an LS (actually L98) and Rover V8 JE 5.2 Defender and despite their very different setup I think the Rv8 suits the car better for everyday use. I would look for a engine around the 300bhp (not American HP) with a great torque line, don't care about pub talk and enjoy a well balanced car, IMO. m |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
You’ve gone to a lot of effort to ![]() |
I was typing something similar ^.
Paul keep her lit as they say here in NI. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
I can't help with any knowledge but what a great project! I will be watching with much interest
![]() ![]() Is the LS3 going in the N reg or the Puma? I love the LS3 90 you see YouTube drag racing. Completely stock looking on all terrains but foot down in a straight line and it rockets! For me that is what I'd want! The other forum member to speak to about LS3 is John Fair, although not seen him about recently. 4x4 Fabrications also have a lot of experience with many engine changes for a professional opinion. Good luck and dont let the naysayers put you off! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
Gee whizz Chicken Drumstick fell out of the wrong side of bed yesterday
![]() ![]() Have a look at 4x4fabrication.co.uk or if you have instagram look them up on there... They've done a bunch of LS conversions and from what I could see they use the LT230 so may be able to help you out with an adapter > 110 XS Double Cab Last edited by hank on 18th Nov 2020 9:40am. Edited 1 time in total |
Thanks for all the comments and support, it is much appreciated. I am really happy to hear opinions for all angles whether they match mine or not, as not knowing about defenders it's really good to hear all.
The major thing that attracts me to the Defender is the flexibilty and the endless options with good support, I've never done anything like this before and for me the fun is in the challenge of making something that is personal and unique to me. However I also want the path of least resistance and having researched this over the last few months to me it seems like the LS3 is the most common options with lots on the road and no real horror stories (that i can find anyway). The project vehicle is going to be the Puma The IVA is a good point and something I've not considered. I've not seen any of these builds on Q plates so was not on my radar, I'll do some research but does anyone know the criteria. All comments are helpful please keep them coming. |
