Home > Puma (Tdci) > Koni shocks 90-5374 and 90-5375 for Puma
Giby_off
Bulgaria 2012 Defender 110 Puma 2.2 SVX Station Wagon Havana
Hi,
Any advise on how to install Koni shocks 90-5374 and 90-5375 (not 90-5374SP1 and 90-5375SP1) on Puma in order to avoid the issues with the rear shocks.
I bought them from paddockspares.com but according to the Sales guy I buy them on my own responsibility because they are for Defender 110 models prior Puma. He said that it happens because of the way rear shocks connects.
The only reported issues that I have found is related to the welded washer on Pumas. The guy said that he had that issue with other shocks and he explained that welded washers shall be removed.
https://it-it.facebook.com/Terrafirma4x4/p...875954603/
Thank you
Post #865815 7th Nov 2020 6:54am
bankz5152
Those should be removed when fitting any new shocks. Cause nothing up trouble.
Drill out the spot weld, cold chisle it off.
Post #865822 7th Nov 2020 8:39am
Co1
Interesting. What trouble do they cause? I have standard height fox shocks, should I have removed them?
Post #865825 7th Nov 2020 9:09am
bankz5152
Click the link.
They can cause the pins to sheer off even under normal.road driving however more common under articulation.
Post #865828 7th Nov 2020 9:22am
Giby_off
I just changed the oil and took a look on the rear original shocks - 120 000km mostly on road and 10% off-road. Their external washers that sit on the bottom are bended. It is clear that they wasn't hit on rock as they stay almost inside the welded ones.
The question now is - could this be the cause that breaks KONI RAID shocks rods on Pumas?
Another useful information that I found was on Gwyn's web site
https://gwynlewis4x4.co.uk/product/shock-b...shock-kit/
These are very important for all + 5 inch LONG TRAVEL SHOCK ABSORBERS, the washers are used to centralize the shock in the shock mount, they help stop the pin of the shock absorber wearing the hole in the upper and lower mounts by holding the pin of the shock in the centre of the hole, 2 per shock absorber are required, they are fitted as in the picture and the reverse on the bottom mount, on later rear axles the original cup washers are spot welded in by 4 spot welds, these must be removed as they restrict articulation and will cause the pin of the shock to brake off, once they are removed you can then fit these new ones as they will allow more movement for the shock bush to flex.
Post #865833 7th Nov 2020 9:42am
Bluest
If those cups are removed, what locates the the pin laterally? That’s the job the cups were doing. Won’t it end up opening out the hole in the axle bracket over time? 2007 110 TDCi Station Wagon XS
Post #865835 7th Nov 2020 9:44am
Giby_off
When I receive shocks - around 10 days I will see their washers. I found this for Koni RAID spear parts
Post #865839 7th Nov 2020 10:01am
Retroanaconda
You fit the separate inner pair of washers which have a locating section that fits into the axle, visible in the photo above.
Post #865859 7th Nov 2020 11:30am
bankz5152
No because washers sit inside the hole which locates the pin.
Not the best pic but you can just about see the shape of the washer.
My 2004 110 and 2002 90 had those cups. I removed them on both, my 110 did 30k miles on TF shocks before swapped to Koni HT Raids since done 15k on and off road with fault.
Post #865868 7th Nov 2020 12:07pm
Bluest
Thanks both, clearly explained. This might be a little job to do next time I change the lower shock bushes. Can you use the standard cupped bushes? 2007 110 TDCi Station Wagon XS
Post #865870 7th Nov 2020 12:22pm
Giby_off
lets hope that removing of the welded washers and installing Koni's will allow me to user those non SP1 Raid shocks without any issues.
Once I have the kit I will report if such washers are available in it.
Post #865950 7th Nov 2020 7:45pm
Giby_off
I spoke with Koni. According to them they do not produce those shocks since 2012. The current model is SP1 and the difference is the dumping characteristics.
Checking with Paddock Spares if they have them in stock since then. The last makes me worry
Post #866250 9th Nov 2020 11:36am
Giby_off
Paddock told me that their shocks are with SP1 at the end produced 2020. Waiting for the shocks now.
I got them a week before and today they have been installed. Front shocks took me 4 hours. Now I can do them for 2. Rear were done for 1 hour.
I put them front ++ and rear +++. They came from the factory with softest setup and my springs are HD.
This setup is firm for not loaded vehicle on one hand but on the other it is very stable in the corners.
Post #866743 11th Nov 2020 4:08pm
