Home > Maintenance & Modifications > Grease guns
Page 2 of 4 <1234>
Ianh
There are a couple of options on the Alemite . The 500 has the rigid pipe, the 500e the flexi pipe. I have the 500e as I find it easier to use in the tight space around the prop. It’s a lever gun, not a pistol grip, but once coupled you have both hands free or can tuck it under your arm and use the “bagpipe method “ Smile. Once coupled I hold the coupler on the nipple and close the leaver a little while I do so this creates pressure and causes the coupler to lock on.
Post #862230 18th Oct 2020 10:45am
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Zed wrote:
Morris K48 as recommended by Gwyn. My grease gun is model 85 by Umeta.
https://www.airlines-pneumatics.co.uk/prod...T040111040
Where do you source 110g cartridges from?
Post #862232 18th Oct 2020 11:02am
Zed
I use standard 400g cartridges. WARNING.
Post #862235 18th Oct 2020 11:20am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Any news on this? Would be game for a group buy so i can bin my bucket of naff grease guns! Thumbs Up 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #863747 27th Oct 2020 7:13am
dorsetsmith
Grease gun from trago mills Falmouth Thumbs Up and grease from bartlett's or mole valley Thumbs Up
Post #863749 27th Oct 2020 7:29am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Ditto
Post #863768 27th Oct 2020 9:54am
kenzle8a
Have we all got a specific model in mind? I can put in a call and see what they can get / pricing. They also do mega deals on lube Shocked
Post #863782 27th Oct 2020 11:05am
jonny
On a related note, I fitted one of these to my grease gun - makes life much easier as it locks onto the fitting and therefore a lot more grease actually goes in than splurges out of the side:
https://www.amazon.co.uk/gp/product/B00XK8...&psc=1
Post #863787 27th Oct 2020 11:46am
Intercept
My requirement is for a reliable one that makes prop UJ greasing easy
Post #863791 27th Oct 2020 11:54am
Those are great, I've been using them for years. There are some situations where they won't fit due to limited clearance, but everywhere else they are a real boon.
Post #863793 27th Oct 2020 11:58am
Does the above fit Puma UJ’s? That’d be my concern? The UJ’s are a pain with the nipple orientation the way they are being a narrow access.
Lost count of how many times with my old one that it wouldn’t lock on. Just makes the job more tedious and even more of a mess. No Guts, No Glory.
Post #863798 27th Oct 2020 12:26pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
https://www.sgs-engineering.com/m18gg-0-grease-gun
Got one of these. Little on the pricey side compared to a manual gun, but works well with the rest of our M18 kit Thumbs Up
Post #863802 27th Oct 2020 12:29pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
As the Alemite had some positive response on here, And no one appears to have anything negative to say on it.
I would suggest that would be a good one to get a price on.
Once a price is available, even if it is dependent on a minimum order number, maybe a count of who definitely wants one can be done.
Post #863813 27th Oct 2020 1:08pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
if it fits the puma front prop easier than removing it etc, then Ill be in Smile Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #863820 27th Oct 2020 1:23pm
It fits mine (the blue ones)! Mr. Green
Post #863841 27th Oct 2020 2:16pm
Page 2 of 4 <1234>
