Home > Maintenance & Modifications > Fuel tank won’t come out - thoughts?
Co1
In with replacing the breather, but hitting a snag! I can’t get the fuel tank guard forward enough because the tank fouls on the floor cross beams. I’ve tried brute force but don’t have enough! There must be a more logical way to remove no?
Post #862065 17th Oct 2020 10:23am
Co1
There is a line in the Haynes manual that says “remove the fuel tank vent pipe from the left rear of the vehicle”. I can’t find anything there!
Post #862067 17th Oct 2020 10:32am
ickle
cut a neat hole in the rear floor - I think Danielle Gardel did a write up on it for a 90, I did it on my 110, silicone a plate over when done.
HTH Keith
Post #862068 17th Oct 2020 10:38am
Co1
Completely the last resort!! Would much rather leave the floor intact.
Post #862069 17th Oct 2020 10:44am
Co1
Just spotted this “Note” in the manual. Ducking marvellous!
Post #862070 17th Oct 2020 11:02am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I went for the YRM replacement guard - this makes it easy in that you cut the corners off the old guard which allows it to be dropped pretty much straight down.
 Rgds.
Chris
Post #862074 17th Oct 2020 11:22am
Co1
Cheers Pacha. My concern with that is getting it back in!! How did you manage it?
Post #862075 17th Oct 2020 11:28am
Pacha
https://yrmit.co.uk/workshops/land-rover-d...placement/
I placed some wooden chocks under the tank to support it whilst I had enough room to swap the breather over. It's easy with the YRM guard as it installs from underneath - I have posted a link which might help?.
To raise it back up I used a small jack and a piece of ply to raise it up and jiggle it back into the correct position.
I take it that you have disconnected the ARB from the underside?. Rgds.
Chris
Post #862076 17th Oct 2020 11:32am
Co1
Cheers. Just spoke to them, off to pick one up now. Did you bother painting it?
Post #862077 17th Oct 2020 11:49am
Pacha
Just gave it a coat of Dinitrol 4010. Rgds.
Chris
Post #862079 17th Oct 2020 11:55am
jst
90 and 110 tanks can both come out the bottom, i have done quite a few of each. They just require a good pry bar at times and use of jack to support weight whilst you manoeuvre it. I have always removed tank and refitted the original guard. Yes its a pain but its doable. The tank is pretty robust. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #862089 17th Oct 2020 1:04pm
Co1
Tanks is out. Is the vent in the right orientation? It was sandwiched down the side with the open end down.
Post #862113 17th Oct 2020 3:20pm
Pacha
You mean the small breather Col?
If so mine ran across the top of the tank to the N/S rear wheel arch and was tucked into the gap between the top of the crossmember and the floor - hooked end laid flat. Rgds.
Chris
Post #862127 17th Oct 2020 4:46pm
Co1
Yep, sorry. Forgot to post the pic. It looks like this where the leak is coming from, seems like a crappy design. Was going to reroute it higher up the breather behind the flap to the rear lights.
Post #862129 17th Oct 2020 5:10pm
Pacha
Looks like it has been cut down at some point - there was enough tube on mine from the tank to the non-return valve so it sat where you are suggesting. Rgds.
Chris
Post #862138 17th Oct 2020 5:47pm
