Home > Puma (Tdci) > Welcome & Defender 2.2 Puma heater problem |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3500 |
Welcome to the forum
If you have air con, and the air con button is depressed, the fan will work on O. Turn the air con off and the fan should stop Hope that helps. |
13th Oct 2020 6:42am |
tobyrm1 Member Since: 13 Oct 2020 Location: Bristol Posts: 6 |
I do have the aircon button pressed. I will go out later and check. It didnt even occur to me that it would prevent the fan from being turned off!
Thanks for your help! |
13th Oct 2020 7:08am |
Not a problem
13th Oct 2020 7:40am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4210 |
The reason it does that is to prevent ice forming on the AC evaporator when the air con is on. With no airflow it’s possible that the ventilation to the cabin could be completely blocked off by ice. 2007 110 TDCi Station Wagon XS
13th Oct 2020 7:59am |
Makes total sense!
13th Oct 2020 8:54am |
