Home > Maintenance & Modifications > Worklight Disassembly
deskjockey
2009 Defender 110 Puma 2.4 USW Galway Green
Evening chaps
I've recently inherited responsibility for a 110 that belonged to a family member. One of the many tasks I'm looking at is getting the rear worklight back up and running, but I'm now at the point where my options have been reduced to violence and swearing, or coming cap-in-hand to the internet.
It's a genuine one, believe the part number is RTC8921AA. Looks like this:
I've got the grille/lens off, but that's as far as it'll go. The metal reflector is in what I'd call "sh*t state" as the light has obviously spent a while full of rainwater. I'm not sure if the reflector is supposed to pull/lever out or if I'm missing something?
Would appreciate any tips for getting it into pieces to work out exactly what needs replacing (other than the gasket and reflector, obviously!)
Post #860687 9th Oct 2020 6:26pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
At the bottom of the plastic casing, near to the mount, there is a small hole. Use a narrow flat blade screwdriver in this hole to (carefully) pry out the glass lens. Then do the same with the metal reflector and hey presto you’re in.
When reassembling, please note there is a tiny lug on the edge of the glass lens that slots into the corresponding cut-out in the plastic bowl.
Post #860694 9th Oct 2020 6:59pm
deskjockey
Much obliged! I obviously need to try a bit harder. The metal in that area is rather crumbly so I'll probably need a new one anyway once it's off Rolling Eyes
Post #860695 9th Oct 2020 7:03pm
I used to use these light all the time on my very first 90.... thought they were the dogs danglies (but they break easily where the balljoint is moulded into the lamp "head")
Then I discovered they were just lucas units and I could get them for about 1/3 the price that LR were charging.
Post #860705 9th Oct 2020 7:59pm
rockster57
^^^ Available at very reasonable prices. It’s possibly not worth the pain of looking around for replacement parts or renovating. I bought two brand new (LR) units online for buttons!
Corrosion seems to be an issue so although mine were brand new, I sprayed additional coats of black paint then lacquer on the painted parts. Also stripped out the reflector to spray both sides with heat resistant clear lacquer. I’ve also replaced the bezel screws with stainless. OCD is an affliction! Rolling with laughter
You can also replace the standard bulbs with LED equivalents if you’re that way inclined Thumbs Up
Post #860714 9th Oct 2020 8:22pm
rockster57
diesel_jim wrote:
I used to use these light all the time on my very first 90.... thought they were the dogs danglies (but they break easily where the balljoint is moulded into the lamp "head").
I wasn’t aware of this. That balljoint is a friction clamp. If it’s too loose, the light will slop around. If it’s too tight and the angle is adjusted often, this will strain and weaken the mount and no doubt lead to the failure Jim refers to. There is probably a “sweet spot” for torquing up the joint. However, I’ll simply clamp up at a useful angle and then leave it there. Thanks for the info Jim Thumbs Up
Post #860723 9th Oct 2020 8:54pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I replaced three in two years on a 90 I used to own, once they start to rust I found it was a waste of time and effort to even think if tidying them up, disconnect the feed cables and replace with something better that a Land Rover product. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #860797 10th Oct 2020 10:04am
deskjockey
Cheers all for the tips.
It’s looking like the reflector isn’t going to come out in one piece so I’ll start shopping around for a replacement and make sure it gets a good dose of silicone in addition to the naff foam gasket!
Post #860799 10th Oct 2020 10:10am
That takes me back. In their day they were good but the mesh would flake and rust after not too long and then the reflector went and the rear switch never seemed to be far behind. Durites seemed to be the upgrade after that and now I wouldn't bother with anything less than a modern LED.
Post #860854 10th Oct 2020 5:01pm
Litch
Yep, excellent lights with a great light spread
I had one on my S111 SWB V8 and then when I got the 101 I fitted a pair to the windscreen brackets.
Agree about the mesh rusting but other than that they were very tough units.
Still got two in the garage but with the progress of LED lights I can't see me ever fitting them to the 90.
 ONE LIFE, GET IT!
Post #860860 10th Oct 2020 5:10pm
Snap!
Post #860940 11th Oct 2020 9:47am
