Home > Puma (Tdci) > Exhaust smell in cab |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
Sometimes if the wind is blowing from rear to front, the heater intake can draw in fumes from the outside, it's quite common.
I park with my truck parked next to a wall in the morning and it fills up the cab as the fumes just stack up against the wall and the heater intake sucks them in. |
8th Oct 2020 1:31pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Might be a thing, might not, but mined smelled like hot oil for a couple of weeks leading up to an intercooler hose failing.
Also worth checking is the crankcase vent hose. Roaming around đłđ´đ¨đ |
8th Oct 2020 2:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20351 |
Check the foam gasket on the intake ducting to motor assembly, these often part and leave a gap drawing engine bay air in.
I fitted a second gasket to mine and has been good ever since. $W33T $0U7H3RN $UG4R đŹđ§đ´ó §ó ˘ó Ľó Žó §ó żđ´ó §ó ˘ó ˇó Źó łó żđ´ó §ó ˘ó łó Łó ´ó żđŽđŞđşđ¸â˝ď¸đ˘ď¸âď¸đ§°đŞ |
8th Oct 2020 3:09pm |
tamar817 Member Since: 07 Nov 2019 Location: Durham Posts: 9 |
I had the same sort of thing, but with smoke. I just accepted it as a land rover feature, because it happened on my last one. It went away after I had the hoses done. Apparently the fault should have shown up sooner but the remap was preventing it. |
17th Oct 2020 10:22am |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 874 |
Had the same just before I lost power due to a split intercooler hose. Was an easy fix.
17th Oct 2020 11:11am |
