![]() | Home > Puma (Tdci) > Exhaust smell in cab |
Sometimes if the wind is blowing from rear to front, the heater intake can draw in fumes from the outside, it's quite common.
I park with my truck parked next to a wall in the morning and it fills up the cab as the fumes just stack up against the wall and the heater intake sucks them in. |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Might be a thing, might not, but mined smelled like hot oil for a couple of weeks leading up to an intercooler hose failing.
Also worth checking is the crankcase vent hose. Roaming around π³π΄π¨π |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
Check the foam gasket on the intake ducting to motor assembly, these often part and leave a gap drawing engine bay air in.
I fitted a second gasket to mine and has been good ever since. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
tamar817 Member Since: 07 Nov 2019 Location: Durham Posts: 10 ![]() ![]() ![]() |
I had the same sort of thing, but with smoke. I just accepted it as a land rover feature, because it happened on my last one. It went away after I had the hoses done. Apparently the fault should have shown up sooner but the remap was preventing it. |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Had the same just before I lost power due to a split intercooler hose. Was an easy fix.
