Home > Maintenance & Modifications > Fitting side steps - riv nut query! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
You need this sort of thing:
https://www.part-on.co.uk/product/m6-flat-...nut-100pk/ https://www.fastenright.com/general-fixing...n-end/rn06 These links are chosen at random as examples, do not assume that these are the right size. |
17th Sep 2020 3:17pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Here you go. It’s item 10.
(I’m on with the same job on my 110). Click image to enlarge Click image to enlarge |
17th Sep 2020 3:33pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
As above, but it should be in the kit?
A tip if you use the vehicle off road is to flip the support bar around end to end and fit it upside down so that it is a couple of inches higher along its length. It makes it less likely to hang up off road and bend the steps back. Doesn't quite look right but looks better than it does after you smite it on a rock! --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
19th Sep 2020 9:10am |
Packster82 Member Since: 15 Jul 2020 Location: Cirencester Posts: 24 |
Thanks guys, the kit I bought was from Bearmach and included round rivnuts so looks like I’ll need to get hold of some hexagonal ones then should be job done. Thanks for the tip Bogmonster, I did think you lost quite a bit of ground clearance installing as per the instructions.
19th Sep 2020 9:34am |
