![]() | Home > Puma (Tdci) > Should I buy 2.4 110 XS now or wait for 2.2 in December? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2661 ![]() ![]() ![]() |
The short drives can be an issue, but the most important factor in this part of the world is diesel quality! Someone I know on the local Audi forum had an issue with his TDi - a sample of the 50ppm diesel from the reputable petrol station he uses returned a result of 85ppm. Not to mention the horror stories of people with blown injectors, failed fuel pumps, etc, due to water in the diesel, dirt, paraffin, etc. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
probably more defenders than transits about, ford lost the panel van sector years ago.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5070 ![]() ![]() ![]() |
I know that definitely isn't the case - im sure LR would like it to be Mike |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
i would probably get the 2.2 as it wil get the cheaper tax etc. Dont think there is really much point worrying about if its a 2.2 or 2.4.
You only need to worry if you want bragging rights over your mates in the pub; and if thats all your interested in then a TD5 will win the CCs and Cylinders argument. ![]() Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
True, but Transits are not as common as they used to be, Merc Sprinters seem to dominate the market now, even the police and public utilities going over to them. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
Check out this from Volvo.
http://www.volvoclub.org.uk/diesel_filter.shtml A small extract from what it says.. Do I need one? The fitment of a particulate filter to diesel-engined cars is becoming increasingly commonplace in order to meet emissions legislation and to achieve cleaner exhaust gases. Nevertheless, driving constraints in such locations as inner-city and islands (e.g. Channel Islands, Isle of Man) are unlikely to facilitate passive regeneration. Please consider your driving style and normal driving conditions to determine whether a diesel- or petrol-engined car is best suited to meet your needs. Your Volvo dealer will be pleased to assist you -------------------------------------------------------------------------------- 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
There all commercials, so there is no difference in the tax as VED not based on emissions for commercials. Disco 3 gone but the memory of the bills remain... XS 110 Utility maybe one day..... (did they fix the quality yet?) |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
I have a DPF on the audi, the service tech told me if you don't thrash the b0ll0x of it when the amber light comes on irrevocable damage is done and the dpf has to be replaced. It is considered customer damage and wont be done under warranty. Cost - £1100 fitted.
Seen as more than every other defender is a lemon already (according to the forum poll!)then expect some fun and games. Pom |
MacDefender Member Since: 17 Aug 2011 Location: Caxias do Sul Posts: 16 ![]() ![]() ![]() |
The end of an era, my friends.
Diesel engines are becoming more and more unattractive on Land Rovers. I don't know how the new 2014 Defender will look like, but I can imagine a petrol engine running inside... After the 4X2 Freelander, what will be the next surprise? Land Rovers are becoming more and more "americanized" unfortunately .... ![]() |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2656 ![]() ![]() ![]() |
I can see the TD5 going up in value
Good for me ![]() Mark |
I'd be interested to know what changes have been made to tbe rear door lock - maybe more secure ?
more rust added. Pom |
carefull pom or I'll get BT to call you ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
if you are going to be regularly driving on trips of 10 miles or more then the 2.2 will be fine. If you will be doing mostly short trips on a cold engine then the 2.4 will be less problematic IMHO
