Home > In Car Electronics > Defender TD5 Cruise Control
Page 1 of 4 1234>
bankz5152
Could anyone give me a hand with fitting cruise control to a 2004 Defender!
Got most of it done but a little stuck on the final wiring.
Im using a D2 switch with Set+/Resume and a push to activate switch to turn on and off.
Been following this diagram -
So far Ive joined pin 10 & pin 15 and run 3 wires up to the steering column and the On/Off switch is installed and ready.
However the diagram shows 4 wires ive only got 3 on the D2 switch - Blue, Black & Green im not sure which is which!
Anyone know how I match the diagram above to the D2 CC switch? Instagram @defender_ventures
Empire Tuning - Agent
Post #855062 9th Sep 2020 4:45am
grafty99
As a guess I'd say black is common and blue/green is set/resume.
A multimeter would tell you Thumbs Up
I think Ray (Mk1collector) used a D2 switch Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #855109 9th Sep 2020 8:16am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Bankz if you don't have any luck, I can go pull my steering column off to check the wiring colours after work Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #855128 9th Sep 2020 8:57am
Martin
Site Admin
Black is the common input to both switches - connect this to the red cruise supply line from above diagram.
Blue is the "RES" (resume) output wire
Green is the "SET+" output wire
I can supply the 3 pin plug and terminals or crimped wires if you need.
For what it's worth I don't agree that that diagram is totally correct, it supplies 12V to the "brake off" input (pin 10) at all times when the cruise is switched on, when it should break to open circuit when the brake pedal is pressed. You can do this with a small changeover relay operated from the brake pedal output.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #855131 9th Sep 2020 9:09am
roel
I have this schematic:
However my power supply does not come from the ecu as I don't use the clutch sensor. That is not a problem as the ecu sees a speed and rpm difference if you depress the clutch and will cancel the CC too.
You don't really need a master on/off switch as the CC only starts working after you push the set/acc butoon and cancels after you push cancel/resume or the brake or Clutch pedal.
I found that I never switch it off.
After a small search on the web:
This is what I use.
So it is the same as yours.
For the switch use a multi meter or a light to see how the switch works. Roel
2003 90 Td5 (2009-now)
Post #855151 9th Sep 2020 10:49am
bankz5152
Wonderful. Thank you!
Should have asked on here first! Found a 3 plug on ebay and used that! Hopefully i wont wreck it again.
Will the pin10 cause me any issues wired as per the diagram? Instagram @defender_ventures
Post #855158 9th Sep 2020 11:34am
roel
I don't think pin 10 will give issues as I use it too. Roel
Post #855367 10th Sep 2020 6:49pm
bankz5152
Ok slowly getting there!
D2 switch is in and wired as per the replies.
Just looking for a good switched 12v behind the gauges any suggestions? Instagram @defender_ventures
Post #859792 4th Oct 2020 5:34pm
grafty99
Speedo, fuel gauge and temp gauge all have ignition live feeds Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #860139 6th Oct 2020 7:50pm
bankz5152
Ahh Cheers Grafty! Instagram @defender_ventures
Post #860144 6th Oct 2020 8:05pm
grafty99
1990 Vogue SE
Post #860150 6th Oct 2020 8:35pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Im just getting round to doing this using the same diagram roel produced (2nd one)
Mines an old td5 but im using an NNN ecu so i assume it should work fine.
Ive got a 1.2 transfer box so i know i need a speedo healer. Is it possible to test the CC before splashing out on the speedo healer? I think i read somewhere it might engage in 4th but not 5th with a 1.2 box, is that right?
Also when i do buy the speedo healer does it have to be installed somewhere different to its normal postion? I seem to remember reading somewhere you have to wire it in somewhere else. Will it all make sense when i buy one?
Post #863933 27th Oct 2020 9:34pm
bankz5152
Thatd be good to know. I've not finished wiring mine in yet, should get it done this weekend after I triple check the wiring and finally get the 12V live feed in.
Mines totally different being on 285/75 tyres, 1.3 TX box anc higher ratio 5th..... Instagram @defender_ventures
Post #863937 27th Oct 2020 9:54pm
LandymanStefan
I’m hoping to have mine done this weekend too. Where are you taking your iginition live from?
I’ve gone around with a meter and I think I’m taking mine from the white cable going to the wiper stalk. When I fitted the Rev counter I re did the loom for the clocks and don’t really want to open that up again. Also don’t want any additional plugs to the clocks than the standard ones.
Post #863953 27th Oct 2020 10:43pm
LandymanStefan
Got all the wiring in and finished this evening. With the engine running on the drive I switched on the master switch and it showed on nanocom and cruise control on so I’m very pleased. I didn’t got for a test drive though as on the nanocom it also showed my clutch switch isn’t working, just constantly saying ‘off’
Does anyone know the part no for a td5 clutch switch and do I need it or will it work unplugged?
Post #864317 29th Oct 2020 7:42pm
Page 1 of 4 1234>
