Home > In Car Electronics > Defender TD5 Cruise Control
Page 4 of 4 <1234
bankz5152
Huge thank you to Gareth at Empire Tuning! He retweaked my map until the CC worked properly Very Happy
Cruise control can work if you have non standard ratios! Will make motorway run so much better Instagram @defender_ventures
Empire Tuning - Agent
Post #874377 23rd Dec 2020 4:19pm
Chewyrab
United Kingdom 2001 Defender 90 Td5 Braemar LE Blenheim Silver
Martin wrote:
Black is the common input to both switches - connect this to the red cruise supply line from above diagram.
Blue is the "RES" (resume) output wire
Green is the "SET+" output wire
I can supply the 3 pin plug and terminals or crimped wires if you need.
For what it's worth I don't agree that that diagram is totally correct, it supplies 12V to the "brake off" input (pin 10) at all times when the cruise is switched on, when it should break to open circuit when the brake pedal is pressed. You can do this with a small changeover relay operated from the brake pedal output.
Afternoon gents. Does anyone have a schematic explaining the pin outs for brake 2 to show on diagnostics?
I have a stand alone loom on a series car and I've added cruise control but on diagnostics I cannot simulate the brake 2 switching.
Thanks.
Post #1053243 28th Nov 2024 5:26pm
Page 4 of 4 <1234
