Home > Maintenance & Modifications > Wrong Indicator Stalk - Is There An Adaptor Out There? |
MaxB Member Since: 26 Jun 2020 Location: Southampton Posts: 8 |
Click image to enlarge |
9th Sep 2020 8:18am |
No pictures Max, or any indication (ha!) of the age of vehicle that you're repairing but I'm guessing that one has the earlier bullet type connectors and the other blade connectors? Whilst it wouldn't be impossible to make an adapter (I don't know of anything off the shelf), it would be far easier to just buy the correct part. Space inside the steering column trim is very limited.
Edit: pictures now appearing Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
9th Sep 2020 8:19am |
Click image to enlarge This is the second photo. Apologies, I found it far more difficult to upload those than it should have been! |
9th Sep 2020 8:21am |
Thanks Darren.
Yeah I feel that is probably what I'll end up doing. Just thought I'd put out a last ditch attempt to save me ordering another part haha, thanks anyway! |
9th Sep 2020 8:24am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2225 |
if you dont want to swap the one you have already have then do you have the old stalk still?
If so you could cut the connector off the old stalk and off the new stalk and solder the old connector wires onto the new stalk. Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Sep 2020 8:33am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
If you cut off the connector and ~4 inches of cable from your old stalk I can make it into an adapter for you.
Martin 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Sep 2020 8:43am |
Hi Steve,
Yes I still have the old stalk however I'm not sure I have the kit nor the knowledge to attempt soldering haha. Thanks for your reply! |
9th Sep 2020 8:50am |
Hi Martin,
That's a very kind offer however I feel with the time and effort that would take I may as well just order the correct part as they're not all that expensive. Massive thank you though, very much appreciated. Max |
9th Sep 2020 8:51am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1982 |
If the original seller of the incorrect part won’t refund or exchange the part, perhaps with a small hit on monies due to restocking, you can always put it up for sale on here and potentially get some money back.. there is bound to be someone who will buy it as it’s the right part for their defender.
9th Sep 2020 12:39pm |
