Home > Maintenance & Modifications > Wrong Indicator Stalk - Is There An Adaptor Out There?
MaxB
Hi all,
I’ve recently had issues with my headlights so decided to replace both the main headlight switch and the indicator stalk. I managed to fit the headlight switch with no issues but then in the process of fitting the indicator stalk I realised I ordered the wrong one.
I was wondering if anyone knows if there is an adaptor out there that will allow me to plug this in?
Picture 1 - the new (wrong) indicator stalk
Picture 2 - the connection point that it needs to be plugged in to.
Post #855107 9th Sep 2020 8:14am
MaxB
Post #855110 9th Sep 2020 8:18am
No pictures Max, or any indication (ha!) of the age of vehicle that you're repairing but I'm guessing that one has the earlier bullet type connectors and the other blade connectors? Whilst it wouldn't be impossible to make an adapter (I don't know of anything off the shelf), it would be far easier to just buy the correct part. Space inside the steering column trim is very limited.
Edit: pictures now appearing Smile Darren
Post #855112 9th Sep 2020 8:19am
MaxB
This is the second photo. Apologies, I found it far more difficult to upload those than it should have been!
Post #855113 9th Sep 2020 8:21am
MaxB
Thanks Darren.
Yeah I feel that is probably what I'll end up doing. Just thought I'd put out a last ditch attempt to save me ordering another part haha, thanks anyway!
Post #855115 9th Sep 2020 8:24am
rallysteve
if you dont want to swap the one you have already have then do you have the old stalk still?
If so you could cut the connector off the old stalk and off the new stalk and solder the old connector wires onto the new stalk.
Post #855119 9th Sep 2020 8:33am
Martin
Site Admin
If you cut off the connector and ~4 inches of cable from your old stalk I can make it into an adapter for you.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #855121 9th Sep 2020 8:43am
MaxB
Hi Steve,
Yes I still have the old stalk however I'm not sure I have the kit nor the knowledge to attempt soldering haha.
Thanks for your reply!
Post #855124 9th Sep 2020 8:50am
MaxB
Hi Martin,
That's a very kind offer however I feel with the time and effort that would take I may as well just order the correct part as they're not all that expensive. Massive thank you though, very much appreciated.
Max
Post #855125 9th Sep 2020 8:51am
Ianh
If the original seller of the incorrect part won’t refund or exchange the part, perhaps with a small hit on monies due to restocking, you can always put it up for sale on here and potentially get some money back.. there is bound to be someone who will buy it as it’s the right part for their defender.
Post #855168 9th Sep 2020 12:39pm
