Home > Puma (Tdci) > Oil Everywhere!
Page 2 of 2 <12
ior
England 2007 Defender 90 Puma 2.4 XS CSW Caledonian Blue
Yes correct. Sorry should have clarified.
Post #812678 30th Jan 2020 12:10pm
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
Thumbs Up Thumbs Up
If anyone's interested I got mine from MM4x4. They cost £19.84 for all four and are Elring. Part no is LR004662 Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #812680 30th Jan 2020 12:13pm
AndyS
Thanks everyone for your input and I did read them as they were posted but it all got a bit above me so I kept quiet. Very Happy
I'm really short of money at the moment so I saved and put money aside and finally got the local mechanic to change the fuel pump cover as he said sometimes the gasket goes hard and stops sealing. Sounds feasible but it totally didn't work, it's now ten times worse. This is the drip off after a ten mile drive whereas it wasn't really dripping much before with my 'rag poked down the back of the pulley housing' bodge. This is under the car, you can imagine what it's like under the bonnet.
The local mechanic has taken the car off the road as I can't drive it like this, it's too dangerous for motorcycles and cyclists. I took it back to him today and he suggested changing the vacuum pump gasket but it's leaking out of the fuel pump cover so that's just throwing more money at it without an actual fix in sight.
I should have done it myself in the first place. I'm used to working on Minis and the Defender seemed too complicated but I've got to the point where if you want something done properly, do it yourself.
What size spanner is the fan nut?
Post #854312 4th Sep 2020 7:25pm
spudfan
Ireland
Check where the dipstick goes into the engine. There is a rubber "O" on the tube that sometimes needs replacing. Cured an oil leak I had.
Also gasket seals at the side of the engine at the manifold go and oil gets forced out . Both are inexpensive to fix. Hopefully one of these is your problem. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #854574 6th Sep 2020 3:33pm
dannyragsdale
Papau New Guinea 2012 Defender 110 Puma 2.2 HT Fuji White
Did you ever figure out where the leak was coming from, Andy? I am having a similar issue.
Post #1020058 4th Jan 2024 5:34am
Page 2 of 2 <12
