Home > Puma (Tdci) > Confused! |
Defendit Member Since: 31 Oct 2010 Location: Down Under Posts: 26 |
Have you checked your bonnet hinges? See my post below. http://www.defender2.net/forum/topic7800.html I suspect many cars may have this issue. |
19th Aug 2011 10:03pm |
shrekman Member Since: 11 Aug 2011 Location: worcestershire Posts: 20 |
sounds like the gearbox to chassis earth lead ..... ???? could the exhaust have melted it ???? spent 20 years fixing them ... the dealers just wont listen !!!! |
19th Aug 2011 11:43pm |
churchy Member Since: 28 Jul 2011 Location: UK Posts: 237 |
Hi all,
Well the rattle was traced to a heat shield - apparently fixed but rattling again within hours. I believe its the issue with the rear brake calipers as I seem to be able to move the pins if I poke my finger through the wheel. It also does not rattle if I go over a bump in the road whilst braking. Secondly it's still whining - mainly at 50-70mph but also regularly at lower speeds - thinking the common gasket issue. I have pointed the dealer in the direction of both the above, they're coming to collect the car this morning so it's back to the dealer for the third time............. Feel like a fussy customer and I accept it's not all going to be 100% for a 2nd hand car but part of me also thinks I shouldn't put up with it or do the hard work for them........ On the plus side they did fix the reverse light issue and replace an oil seal so not all bad! Fingers x! |
31st Aug 2011 8:50am |
A few back & forth phone calls later and a lot of internal decision making @ Land Rover and finally I have my wagon back with a new turbo!
It seems they finally relented and agreed that the whistling and whining was a knackered turbo and a fault rather than a feature (as I had previosly been told!!!!!!) All currently seems well but they could not fix the rattle..........I am convinced it's the brake pad / caliper issue as I am sure its not correct to be able to push the pins in the brake pads assembly about with your fingers through the back wheels............ |
6th Sep 2011 4:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
The pad retention pins are designed to be a loose fit to allow the pads to move freely, so what you are finding is entirely normal.
The rattle is (imho) really down to penny-pinching on the design of the "anti-rattle" ( ) springs, which are simple coils around the pins between the pads and almost completely useless. If your springs are deteriorated, it might be worth fitting new ones, but it may not make the slightest difference. It would not be difficult to design a spring which actually does the job, but I don't know of any available off the shelf. |
7th Sep 2011 11:48am |
