Home > My Defender > here she is
Page 21 of 26 <123 ... 202122 ... 242526>
razz
2001 Defender 90 Td5 PU Caledonian Blue
She’s had a de-pit wash , got some nice smelling cleaner and she’s so much better . Have stripped off the rear tub wings , mine are separate as I cut them up yonks ago , all bulkhead bolts are loose , so once she’s dry , I’ll reposition the tub so me doors line up and shut again , big bonus having the day off . Lovely jubbly
Post #851680 24th Aug 2020 10:32am
razz
The rear wings were looking rough around the edges , so cut them off . Tub is all but done too . Need to get it out of the garage for final line up and tighten . Few jobs I gonna look at in the future , move the rad to the rear , get a winch in the front but not sticking out by a mile , might even get a tube arse end too , but time will tell . One thing noticed , I have to remove me roof to get it into the garage , when I remove all excess weight , I can’t get it in at all , may look to going back to the series screen idea
Post #851704 24th Aug 2020 1:28pm
razz
Cleaned up some parts and painted , have ordered some Ali brackets , once they arrive I’ll rebuild
Post #851773 24th Aug 2020 6:39pm
L110CDL
Loving that temp snorkel Wink
It's surprising what you can get done on your day off Very Happy Clayton.
Keeper.
Post #852000 25th Aug 2020 7:45pm
razz
Cheers dude Thumbs Up after a days graft it’s hard work in the evenings sometimes , in the mean time , I have repositioned then tank to the rear , but have raised it to prevent damage at the pit , this will free up the area for a rad and poss central winch . Will weld it all up another night
Post #852187 26th Aug 2020 6:06pm
razz
From Sunday
Post #852209 26th Aug 2020 7:09pm
L110CDL
Great pic's there and the 90 looking right at home Thumbs Up
The snorkel worked all okay i take it Very Happy Clayton.
Keeper.
Post #852248 26th Aug 2020 8:33pm
razz
Here there , yep the snorkel worked perfectly , although I still don’t think a snorkel is required unless the lake is 4ft plus deep , you can see the air intake is clear because of the bow wave , the pic here is when the lake is deeper , snorkel is needed then
Thumbs Up
Post #852432 27th Aug 2020 5:26pm
L110CDL
Yes i did notice the vent was visible but you just never know if there is a sudden hole Shocked but for sure you need the snorkel when over 4ft deep Thumbs Up Clayton.
Keeper.
Post #852730 28th Aug 2020 7:30pm
razz
cheers fella , i sit and watch others Thumbs Up and when they disappear under water , i avoid them bits Thumbs Up
a little more done on the new tank position , the td5 tank hanger brackets arrived and i modified to suit , a smidge of welding and shes spot on , a coat of gravitex and bobs your uncle , next up , re-wire and re-plumb the tank , then it rear bulkhead mod time
Post #852914 29th Aug 2020 1:33pm
razz
Bye bye 8mm nuts n bolts and Penny washers and hello to a 10mm thick block of Ali and 10mm bolts , she’s a lot less floppy now , will repeat on the other side when I have turned her around
The tank is in , lots of clearance , had to modify the cradle to get my D rings in , she’s plumbed in to , temp electrics fitted to bled and run to check for leaks , and guess what , no leaks , next up , drivers side rear wing
Post #852984 29th Aug 2020 7:17pm
razz
Lots of small garage visits today , the drivers side of the tub is fitted and I spent a little time lining things up , behind the scenes are much stronger Ali brackets , bigger bolts and bigger rivets , so much stronger now , more odds n sods ordered , next up , do some wiring
Post #853164 30th Aug 2020 7:04pm
L110CDL
Great work going on and with the tank, good result with no leaks Thumbs Up Clayton.
Keeper.
Post #853435 31st Aug 2020 8:05pm
razz
Have started on the other side at last
Post #854098 3rd Sep 2020 6:22pm
L110CDL
Thumbs Up Clayton.
Keeper.
Post #854318 4th Sep 2020 7:37pm
