Home > My Defender > here she is |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
The rear wings were looking rough around the edges , so cut them off . Tub is all but done too . Need to get it out of the garage for final line up and tighten . Few jobs I gonna look at in the future , move the rad to the rear , get a winch in the front but not sticking out by a mile , might even get a tube arse end too , but time will tell . One thing noticed , I have to remove me roof to get it into the garage , when I remove all excess weight , I can’t get it in at all , may look to going back to the series screen idea
Click image to enlarge Click image to enlarge Click image to enlarge |
24th Aug 2020 1:28pm |
Cleaned up some parts and painted , have ordered some Ali brackets , once they arrive I’ll rebuild
24th Aug 2020 6:39pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
Loving that temp snorkel
It's surprising what you can get done on your day off Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
25th Aug 2020 7:45pm |
Cheers dude after a days graft it’s hard work in the evenings sometimes , in the mean time , I have repositioned then tank to the rear , but have raised it to prevent damage at the pit , this will free up the area for a rad and poss central winch . Will weld it all up another night
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
26th Aug 2020 6:06pm |
From Sunday
26th Aug 2020 7:09pm |
Great pic's there and the 90 looking right at home
The snorkel worked all okay i take it Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
26th Aug 2020 8:33pm |
Here there , yep the snorkel worked perfectly , although I still don’t think a snorkel is required unless the lake is 4ft plus deep , you can see the air intake is clear because of the bow wave , the pic here is when the lake is deeper , snorkel is needed then
27th Aug 2020 5:26pm |
Yes i did notice the vent was visible but you just never know if there is a sudden hole but for sure you need the snorkel when over 4ft deep Clayton.
28th Aug 2020 7:30pm |
cheers fella , i sit and watch others and when they disappear under water , i avoid them bits
a little more done on the new tank position , the td5 tank hanger brackets arrived and i modified to suit , a smidge of welding and shes spot on , a coat of gravitex and bobs your uncle , next up , re-wire and re-plumb the tank , then it rear bulkhead mod time Click image to enlarge Click image to enlarge |
29th Aug 2020 1:33pm |
Bye bye 8mm nuts n bolts and Penny washers and hello to a 10mm thick block of Ali and 10mm bolts , she’s a lot less floppy now , will repeat on the other side when I have turned her around
Click image to enlarge Click image to enlarge The tank is in , lots of clearance , had to modify the cradle to get my D rings in , she’s plumbed in to , temp electrics fitted to bled and run to check for leaks , and guess what , no leaks , next up , drivers side rear wing Click image to enlarge Click image to enlarge |
29th Aug 2020 7:17pm |
Lots of small garage visits today , the drivers side of the tub is fitted and I spent a little time lining things up , behind the scenes are much stronger Ali brackets , bigger bolts and bigger rivets , so much stronger now , more odds n sods ordered , next up , do some wiring
30th Aug 2020 7:04pm |
Great work going on and with the tank, good result with no leaks Clayton.
31st Aug 2020 8:05pm |
Have started on the other side at last
3rd Sep 2020 6:22pm |
Clayton.
4th Sep 2020 7:37pm |
