Home > Puma (Tdci) > Cracked inner door lock panel |
Liam Murphy Member Since: 29 Jul 2020 Location: South Wales Posts: 94 |
Anyone know of something like this but for the Puma?
Click image to enlarge https://www.ebay.co.uk/itm/RH-Front-Door-I...Swx2FbzGZd The listing says its only up to an '06 buy I'm struggling to find something similar for the Puma Cheers! |
19th Aug 2020 8:21pm |
Puma door fitted from 05 onwords
19th Aug 2020 10:16pm |
won’t find a repair piece as later doors are press form two gav sheet
20th Aug 2020 12:21pm |
s55shh Member Since: 30 Dec 2019 Location: staffs Posts: 192 |
also caused by knackered hinges pushing the door out of alignment for the striker
20th Aug 2020 12:22pm |
Thanks for this! Much appreciated. So these are the cracks in mine, would you weld that in your experience or buy the aforementioned panel and weld either side? Click image to enlarge Either way, I can't weld so I'm going to have to take it somewhere to be repaired, just trying to source everything I need to make it as painless as possible... |
20th Aug 2020 12:43pm |
And this is the upgraded door striker you mentioned too, correct?
https://www.paddockspares.com/x-trouser-door-striker.html I'll get one on order |
20th Aug 2020 12:47pm |
OK, thanks! I'll check the hinges out too |
20th Aug 2020 12:48pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 612 |
Easily repairable. I have a late door with exactly the same damage I mig welded up in 2008 and it is still fine now, I’ve done plenty since. If that was presented to me with door card removed it would be a 20 minute job to sort out. It is not visible when door card on so just needs weld bead painting, no need to worry about making it invisible, It can be done with window in situ just covered over to prevent splatter marks. |
20th Aug 2020 1:00pm |
Perfect! Thanks. I'll take them to a welder as they stand if that's the case.
I also ordered the X-Trouser door strikers too, as the plastic was worn on my OEM ones. I learned that they're designed not to hook on your trousers too, hence the name! Mind blown. Saved a set of corduroys for me there |
20th Aug 2020 8:31pm |
