Home > Puma (Tdci) > Cracked inner door lock panel
Liam Murphy
United Kingdom 2009 Defender 110 2.5 TD HT Tamar Blue
Anyone know of something like this but for the Puma?
https://www.ebay.co.uk/itm/RH-Front-Door-I...Swx2FbzGZd
The listing says its only up to an '06 buy I'm struggling to find something similar for the Puma
Cheers!
Post #851014 19th Aug 2020 7:21pm
dorsetsmith
Puma door fitted from 05 onwords
Post #851039 19th Aug 2020 9:16pm
Oldowner
What a completely useless reply above from someone trying to be clever.
You won’t find a repair piece for the late door due to its construction so you will either have to utilise the above repair piece and modify it, or weld up the original. I have repaired lots of late doors now with this problem.
The doors almost always crack by the door lock button position due to the striker plate being misaligned or the plastic sleeve wearing. This causes the door to need to be slammed harder to get it to shut correctly, which when slammed from the inside using the interior handle causes the upper section of the door to eventually crack. The X eng “X trouser” striker plate goes a long way towards preventing the doors from cracking as they have done away with the plastic sleeve that fails.
Post #851054 20th Aug 2020 4:36am
dorsetsmith
won’t find a repair piece as later doors are press form two gav sheet
Post #851097 20th Aug 2020 11:21am
s55shh
also caused by knackered hinges pushing the door out of alignment for the striker
Post #851098 20th Aug 2020 11:22am
Liam Murphy
Thanks for this! Much appreciated.
So these are the cracks in mine, would you weld that in your experience or buy the aforementioned panel and weld either side?
Either way, I can't weld so I'm going to have to take it somewhere to be repaired, just trying to source everything I need to make it as painless as possible...
Post #851107 20th Aug 2020 11:43am
Liam Murphy
And this is the upgraded door striker you mentioned too, correct?
https://www.paddockspares.com/x-trouser-door-striker.html
I'll get one on order
Post #851108 20th Aug 2020 11:47am
Liam Murphy
OK, thanks! I'll check the hinges out too
Post #851109 20th Aug 2020 11:48am
Oldowner
Easily repairable. I have a late door with exactly the same damage I mig welded up in 2008 and it is still fine now, I’ve done plenty since.
If that was presented to me with door card removed it would be a 20 minute job to sort out. It is not visible when door card on so just needs weld bead painting, no need to worry about making it invisible, It can be done with window in situ just covered over to prevent splatter marks.
Post #851111 20th Aug 2020 12:00pm
Liam Murphy
Perfect! Thanks. I'll take them to a welder as they stand if that's the case.
I also ordered the X-Trouser door strikers too, as the plastic was worn on my OEM ones. I learned that they're designed not to hook on your trousers too, hence the name! Mind blown.
Saved a set of corduroys for me there
Post #851190 20th Aug 2020 7:31pm
