Home > Technical > Puma indicator cutting out ignition/dash |
dazzling1611 Member Since: 08 Jun 2020 Location: morpeth Posts: 35 |
someone must have had the same fault
16th Aug 2020 6:06am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
I would start by unplugging each indicator on that side one at a time and see if it is related to one of your lamps.
Try that first and let us know 1988 90 Td5 NAS soft top 2015 D90 XS SW |
16th Aug 2020 7:01am |
Also does the dash go off with the indicator coming on or off with it off? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th Aug 2020 7:02am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17544 |
Almost certainly an earth fault, check nothing has broken or come off the earth points on the bulkhead in the engine bay, especially on the offside.
16th Aug 2020 8:36am |
cheers for the replies guys , i think ive narrowed it down to a speedo/ dash fault.
i disconnected all the indicator and the fault was still there, changed the flasher relay and stalks , still there. i pulled the clocks out and test the feed into the clocks and 12v to the clocks from the flasher relay then swapped to a different wire when changed the flasher direction stalk , so all ok with the feeds into the clocks , so must be a fault with the clocks. now to find new clocks . |
16th Aug 2020 11:42am |
