Home > General & Technical (L663) > New Defender vs G Wagen off road video
Page 4 of 4 <1234
J77
Rock crawl and the new wade setting are standard TR settings provided the car has air suspension.
Post #846890 29th Jul 2020 4:20pm
Tim in Scotland
Supacat wrote:
I thought rock crawl and a wade mode were also TR2 exclusive?
Wade sensing is new for this version, everything since D3 has had the other 5 settings except Evoque and Disco Sport and coil sprung D3’s which don’t get rock crawl mode and `rRS `dynamics get a further additional setting called, would you believe it “dynamic” that changes throttle, steering suspension settings and the electro-hydraulic ARB to make the car even sportier on road and it really works too as those cars have next to no body roll in fast tight corners. Some Evoque models also have the extra Dynamic mode too but as far as I know FFRR doesn’t get as it spoils the plush ride for their owners. Today’s latest DiscoSpirt and Evoque have a Dynamic model but the adjustable suspension is an optional extra on that as well - basically a Drynamic DisvoSport or Evoque is one with a bit of extra body kit/trim and no handling enhancement. As J77 says the difference between TR1 and TR2 is TR2 has automatic selection of the modes, IIRC you need TR2 to have ATPC . Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #846894 29th Jul 2020 4:41pm
J77
My Velar is R-Dynamic and came with the Dynamic setting and adaptive dampers, makes a big difference to the comfort over cars without. Though I had to get one replaced a month into ownership.
Post #846896 29th Jul 2020 4:46pm
Tim in Scotland
Both my Evoque's came with the continuously auto adjusting suspension - it was called MagnaRide I think Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #846898 29th Jul 2020 4:49pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Re: New Defender vs G Wagen off road video
Supacat wrote:
https://youtu.be/-KL8eWzx-8o
There's definitely something to be said about actual locking diffs rather than an electronic active system with variable slip based on who knows what.
Wow this is very disappointing! Surely LR would be testing the new defender against G Wagons to make sure it could wipe the floor with it in off road conditions?!
Post #861268 12th Oct 2020 11:56pm
Digger2000
Supacat wrote:
Isn't that screen only if you have the e diff fitted in the rear; which begs the question why the wording is different on the screen for vehicles without it?
In the document that image is taken from it describes both diffs as "slip limited":
There's also the dashboard screens which display the varying level of lock of each diff whilst central icon is a locked padlock?
The truth must lie in the way it limits wheelspin ~ if it does this by applying the brakes, either to a wheel or to a whole axle, then it cannot be locked for any duration of time, otherwise as the vehicle moved one or more wheels would be skidding along rather than rotating. It's rather different to having a mechanical lock in the differential itself.
I'm thinking that nothing is ever actually locked, just when you brake the wheel/axle that is spinning faster it transfers the power to the opposite wheel/axle and then balances wheelspin via sensor measurement and multiple braking efforts.
Or have I missed something?
Just been reading that same page about the configurable terrain response (CTR) it’s confusing as above that it states centre is locking differential and rear is limited slip differential but then further down you get to that CTR section and states both are limited slip differentials. I would of thought on a Land Rover Defender they would of at least had one locking differential. Why would they leave such a vital off road component off the production build car? Surely if this vehicle doesn’t beat the competition out there it’s failed especially when it carries the slogan best4x4xfar I’m mind boggled at this. Maybe they have a more serious off road model in the works but at what cost?...
Post #861273 13th Oct 2020 12:35am
Tim in Scotland
One if the issues with a lot of the testers is they show huge amounts of wheelspin in rock crawling mode and seem to have forgotten that autos default to starting off in 1st gear regardless of whether they are in high or low range whereas everyone driving a manual gear boxed car would start off in those situations in low 3rd - they also forget that the auto has a manual shift mode but LR chooses to label it S on the top of the selector. If test drivers and video makers simply moved the gear selector to the left to what would be Sport in high box they would find that in low box and especially with the Diesel engines where maximum torque occurs at 1400rom you can utilise the torque much better using manually selected gears. I’ve found I can easily pull away in low 3rd,4th 5th or 6th and using low 3rd is just like driving my 1996 Defender 90 with next to no wheel spin on pull away on most surfaces. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #861279 13th Oct 2020 5:12am
I'm not sure the testers forgot anything, the very early ones were shaperoned by JRL, and all the associated bumf they were given and no doubt briefed about was how capable the vehicle was probably laboured the point JLR has been highlighting everywhere: the vehicle does it all for you.
o4dn wrote:
At some point, we had to climb a steep slope at the “demo” zone, one that I do in low range in 2nd or 3rd gear with my Puma with a bit of momentum - With the new Defender, the LR instructor told me to leave the new Defender in high range, without any momentum, and the car just climbed, effortless. And that's with road tyres with a normal tyre pressure!
Post #861282 13th Oct 2020 6:02am
Naks
Tim in Scotland wrote:
Because ATPC is not standard on all models, only with the Advanced Off Road Pack and the Towing Pack, it is standard only on the Defender X. I have it on mine but have yet to try it out, I’ll wait until my LRE invite comes through and test it under instruction!
IME, I've found ATPC to be useless on my L494 other than on flat & hard surfaces...
I've tried it in sand, and went nowhere.
I've tried it on rocky trails, and the car kangaroos up the trail, not smooth at all.
I've tried it on gravely trails, and again it's not smooth at all.
Last month I tried it on a gravel hill climb (about 20deg slope), and it kept saying 'ATPC only available for descent' --
Post #861292 13th Oct 2020 6:45am
Tim in Scotland
2 weeks ago on the LRE Dunkeld Adventure Trek day I did, when we had a stop in the afternoon I mentioned that I was using manual shift low 3rd rather than leaving the shifter in D to the lead driver/instructor who is also the owner of the centre. We discussed which settings in TR we had used and he said he too had tried driving the car that way and despite what JLR had told them pre-launch he would now be instructing people the two ways and letting them drive either the LR way or as we found, in manual mode. He agreed that the wheelspin was considerably reduced and when we did some rocky stuff we both found in Rock Crawl this way was also done with less fuss. In an old Defender with manual gears and a low box I was taught that 1st should only be used for control on steep downhills for engine braking not for pulling away or climbing step slopes off-road and to utilise the engines’ s torque and avoid spinning the wheels thus damaging the ground.
There have been numerous comments by yourself and many others about the disappointing amount of wheelspin shown by New Defender in videos and I’m sharing my findings and just saying that there is a way to considerably reduce it or even stop it. You don’t have to agree with me but you won’t be able to test it unless you try it for yourself. All those ECU’s help the car to be quite capable of moving along at less than walking pace but still at peak torque without wheelspin in relatively higher gears than the previous Defender. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #861309 13th Oct 2020 8:32am
Hey, there's no better way to learn a new vehicle than get out there and try it for yourself. For that I applaud you. There is no implied criticism of this or disagreement; I'm just pointing out, as your instructor also did, the contrast with the official JLR views and techniques.
I'd put more faith in your approach to listening to JLR at the moment. If I have a point, it's just that.
Post #861352 13th Oct 2020 10:50am
Philip
I wonder if the outcome might have been different if the Defender had the locking rear diff and a stronger engine; also think that there’s a general tendency to criticise TC operation when you see it controlling a wheel - whereas that same reactive behaviour could, in a particular situation, be operating to give better progress than simply being physically locked across an axle.
There’s a wet grass tug of war video out there between a Sport SVR and a current G63 - the SVR (on giant summer road tyres) wins because of its traction control, whereas the G completely disables all electronic assistance with any of its diffs locked (even just the centre one when done manually, as far as I can tell - which is at least now a more modern multi-plate version).
If the answer to every single situation was a simple locked or unlocked diff, everything would have that because it would be an awful lot cheaper to manufacture and develop than electronically-controlled limited slip/locking diffs used in combination with TC. What is interesting (and I haven’t seen much information about so far) is the new variable torque split system for the six cylinder diesel Defenders - it’s clearly CO2-driven insomuch as it disconnects the front axle when possible, but it can direct torque to any corner as required. Interesting to see what happens in the various TR modes.
Post #861378 13th Oct 2020 2:16pm
jst
we always taught customers to use command shift on anything other than a 3hr freebie from JLR. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #861440 13th Oct 2020 7:21pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
I wouldn't agree with that. There are plenty of climbs where you want to creep up in low 1st at idle in an old model if traction is good.
The only thing certain about 'rules' being taught off road is that at some point in life you'll learn you need to ignore them... ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #861476 13th Oct 2020 9:39pm
Cheshire110
Really interesting video! (Found English subtitles half way though if anyone else didn’t...)
I’d say what I took away from that was how good a new defender with the rear locker would hopefully be. Certainly an essential spec if you want to use more than just basic off road abilities.
I suspect an old/original defender (especially one without traction control or aftermarket lockers) would have struggled quite a bit there - can be embarrassingly hard to get a cross-axled defender going in my experience.
All interesting stuff! Cheers, David
Post #861654 14th Oct 2020 11:26pm
Page 4 of 4 <1234
