Home > General & Technical (L663) > Rear recovery plates/ rings |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1325 |
Agree Supacat. I stand to be corrected, but I don't recall any bracing back to the chassis legs on the military LR's where the NATO pintle was mounted directly on the cross member.
25th Jul 2020 6:14pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 922 |
The MOD defenders might have additional strengthening on the rear crossmember. The old series vehicles had a specific crossmember for such purpose, newer coilers I don't know.
HOWEVER The Nato Hook, Jaw, Pintle , Hitch Whatever I feel is just a Towing device not a Recovery device. But that is another can of worms for another day. As a paraphase of what Andrew s said, Just because it has been done doesn't mean it is the done thing. I'm guilty as charged of using a Dixon bate HD pin hitch as a recovery device but it was on a hitch with bracing legs and it was a minor towing operation. I now have a receiver hitch as I feel it is a safer option. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
26th Jul 2020 4:20pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
ALRC (Association of Land Rover Clubs) have accepted 50mm tow balls, dixon bate pin hitches and NATO hitches as suitable recovery points (providing they are correctly secured) since I started trialing over 25 years ago for RTV , CCV and Comp Safari.
26th Jul 2020 11:16pm |
Yes they do, but the green book has been built on a continual what has been done and not gone wrong so we shall continue to do it this way mentality. In my competitive span I have seen some trying huge forces put through those recovery points and 9 times out of ten it has been a failure of the chassis member around the point. This was the steering of the latest ruling of having a mandatory backing plate on all recovery points. Although TD5's etc with the fixed captive nuts in the rear crossmember are exempt.
I have witnessed a scrutineer who sits on the ALRC SORC demand that a competitor not use the supplied steel pin for the recovery billet on their receiver hitch and use a M10 HT bolt instead. Even though it is no way the right application, he couldn't see it as making the point unsafe. I have used my ALRC knowledge as a basis of what you can get away with in a pinch but i'm always looking on how to improve and find safer ways. It helps us all then. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
27th Jul 2020 5:26am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 |
^^ Given that every receiver hitch I have come across has used a 16mm diameter pin, that is rather disturbing!
27th Jul 2020 10:11am |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
They are now on the Powerful UK website, £95 inc the trim finisher.
https://www.powerfuluk.com/vehicles/land-r...black.html |
28th Jul 2020 8:32pm |
They were on but showing as out of stock earlier, maybe yesterday morning, so there must have been a supply come through.
29th Jul 2020 6:15am |
So JLR have got it wrong on the new Defender as well then? Click image to enlarge |
29th Jul 2020 6:24am |
Interesting to see the designers had a trim finish that got lost somewhere further down the line: Click image to enlarge |
29th Jul 2020 8:38pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Why? 130's have feeling's as well you know |
29th Jul 2020 9:27pm |
Seems a waste to go to the effort of designing them and then not fitting them to production vehicles Even the X doesn’t get them Click image to enlarge |
29th Jul 2020 10:42pm |
MrEleven Member Since: 15 May 2020 Location: Glasgow Posts: 112 |
So im guessing if you could buy the finisher inserts separate, you could just use them with the screw in loops ?
30th Jul 2020 7:11am |
Click image to enlarge When I look at that photo I am struck by how many expensive bits could get damaged in a minor rear-end impact! I suspect that repair bills for this vehicle could be substantial, although I guess that is generally true for all modern vehicles. |
30th Jul 2020 7:50am |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 |
You actually can buy those trim pieces separately.
30th Jul 2020 7:55am |
