But unfortunately far from uncommon ~ is there any vehicle out there that has not been garaged from day one that isn't showing the same? |
chek Member Since: 17 Sep 2015 Location: ZRH Posts: 182 ![]() ![]() ![]() |
Mine isn't. If there is one it's got to be Eric's!
Went to pick up a great condition bonnet today so I can loose the chequer plate on the front of mine
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 ![]() ![]() ![]() |
Had lunch sitting in the back looking out from the North Yorkshire Moors towards Roseberry Topping. There are worse places to eat a sandwich.
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Frustratingly, it has been garaged since day one. And never driven in snow or salt. Chassis is still perfect; this area not so much. ![]() |
So if I was the service manager at my local main dealer, I'd be telling you that you must have been using the windscreen washer excessively.
Just moving from here:
https://www.defender2.net/forum/post842022.html#842022
![]() Click image to enlarge It works fine with seats folded forward. Pipe is just standard 40mm waste pipe - available in a number of colours. Pipes are just secured with a single zip tie. Re-holstering is a doddle - just slide in the pointy end until handle is able to be aligned with cut tube and pull back to sleeve. ![]() Click image to enlarge I think a 3rd umbrella could be fitted between the 2 I have. |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
My Heritage did the same thing. 3 times it was repainted under warranty in 4 years. Very boring. It lived in the garage, had wax / ACF50 on all the right places and still rusted before my eyes. |
I don’t think you can fit another in between those two or the seat won’t fold forward? Ray My build thread http://www.defender2.net/forum/topic17615.html |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1945 ![]() ![]() ![]() |
now i like the umbrella idea
![]() ![]() ![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 744 ![]() ![]() ![]() |
Thank you! Will play around with the ideas a bit to see what fits my situation! |
Did the 5 year / 100,000 km service (67,200km on the clock)
![]() Click image to enlarge ![]() Click image to enlarge Roaming around 🇳🇴🇨🇠|
Went from a BAS 150 map to a 170 this weekend. Well worth the cash for the upgrade, and should have gone for it in the first place. Loads more low end talk and a healthy speed injection. Feels smoother as well. All for an extra £60.
Picked up a spare engine for the lightweight, it’s guna be a while until I will be able to strip and overhaul it so a generous coat of cavity wax was applied prior to storage:
![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
