Page 1278 of 1377 <123 ... 127712781279 ... 137513761377>
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Tr90 wrote:
Changed the seat covers and foams and with the old ones made a cubby box lid.
Good job mate, what foams and covers did you use and how hard or long was the job?
Post #841381 2nd Jul 2020 8:15pm
DeeEss wrote:
And found something disappointing:
But unfortunately far from uncommon ~ is there any vehicle out there that has not been garaged from day one that isn't showing the same?
Post #841564 3rd Jul 2020 4:33pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
Mine isn't. If there is one it's got to be Eric's! Smile
Post #841583 3rd Jul 2020 5:35pm
mk1collector
Went to pick up a great condition bonnet today so I can loose the chequer plate on the front of mine Mr. Green and booked it in for painting when the windscreen surround gets painted, but the paint shop is busy till mid august Shocked Ray
My build thread
Post #841593 3rd Jul 2020 6:06pm
Co1
Had lunch sitting in the back looking out from the North Yorkshire Moors towards Roseberry Topping. There are worse places to eat a sandwich.
Post #841597 3rd Jul 2020 6:24pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Frustratingly, it has been garaged since day one. And never driven in snow or salt. Chassis is still perfect; this area not so much. Rolling Eyes Roaming around 🇳🇴🇨🇭
Post #841641 3rd Jul 2020 8:29pm
So if I was the service manager at my local main dealer, I'd be telling you that you must have been using the windscreen washer excessively. Wink
Post #841706 4th Jul 2020 7:08am
Just moving from here:
https://www.defender2.net/forum/post842022.html#842022
HardCharger wrote:
Supacat wrote:
LandRoverAnorak wrote:
Next up was another small step towards my perfect stowage solution, an umbrella holder! This has to be one of the most simple modifications on the planet, merely consisting of a 750mm length of 2 inch plastic pipe (I know I'm mixing my units Laughing ) cable tied to the rear of the front legs of the '60' part of the second row seats:
This places my umbrella immediately to hand when the door is opened:
An embellishment of the idea could be to drill a series of holes in the side of the pipe to allow a wet umbrella to dry out but I only thought of that after I'd fitted it, so it'll do for now.
If you left it open in the middle, it would air dry, and a lower mounting would allow it to drip onto the rubber mat rather than uncovered metal:
I like this set up! How will they be if the seats are folded forward? What size are the pipes and how are they secured? Difficult to re-holster?
I have a bunch of large umbrellas under the second row and they would thud around during sharp turns. This set up makes things look more "official" plus 2 large umbrellas should be good enough for about 5 people anyways, right? Is there a way to install a 3rd umbrella? I'm realizing that I use one of the large umbrellas just for myself. I guess I can do another holster set up where LRA put his kit Thumbs Up
It works fine with seats folded forward.
Pipe is just standard 40mm waste pipe - available in a number of colours.
Pipes are just secured with a single zip tie.
Re-holstering is a doddle - just slide in the pointy end until handle is able to be aligned with cut tube and pull back to sleeve.
I think a 3rd umbrella could be fitted between the 2 I have.
Post #842026 6th Jul 2020 8:08am
Huttopia
My Heritage did the same thing. 3 times it was repainted under warranty in 4 years. Very boring. It lived in the garage, had wax / ACF50 on all the right places and still rusted before my eyes.
Post #842032 6th Jul 2020 8:24am
mk1collector
I don’t think you can fit another in between those two or the seat won’t fold forward? Ray
My build thread
Post #842055 6th Jul 2020 9:14am
bear100
now i like the umbrella idea Exclamation
Thumbs Up Thumbs Up Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #842146 6th Jul 2020 5:00pm
HardCharger
Thank you! Will play around with the ideas a bit to see what fits my situation!
Post #842242 7th Jul 2020 6:30am
Angus_Beef
Did the 5 year / 100,000 km service (67,200km on the clock)
 Roaming around 🇳🇴🇨🇭
Post #842301 7th Jul 2020 11:30am
Co1
Went from a BAS 150 map to a 170 this weekend. Well worth the cash for the upgrade, and should have gone for it in the first place. Loads more low end talk and a healthy speed injection. Feels smoother as well. All for an extra £60.
Post #842390 7th Jul 2020 6:20pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Picked up a spare engine for the lightweight, it’s guna be a while until I will be able to strip and overhaul it so a generous coat of cavity wax was applied prior to storage:
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #842585 8th Jul 2020 3:29pm
