Home > Maintenance & Modifications > ultragauge drawing power |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
I think that the OBD port is permanently live. Certainly it powers my Nanocom.l up with the ignition off. If the Ultragauge draws it power from there it could well be a constant drain. 2007 110 TDCi Station Wagon XS
28th Jun 2020 2:51pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Yes pretty certain my UG would drain the battery in a couple of weeks.
28th Jun 2020 8:12pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
does your ultraguage stay on when you have turned the engine off??
You can adjust the start up/shut off voltage of the UG in its settings. I have never had any problems with mine and have had it fitted for several years. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
1st Jul 2020 11:42pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
No it shuts down fine and works great, it just draws to much power lately, it never used too though.
And only works with the ignition on. Interesting! I will have to look through the instructions 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd Jul 2020 5:56am |
Mine is set quite high so only turns on when the engine is on (alternator numbing) and off when engine off. So below 13V 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
2nd Jul 2020 12:15pm |
