Home > Maintenance & Modifications > ultragauge drawing power
bear100
i have noticed a battery drop with the 110, i did notice it before i fitted the new optimas but was only slight of around 28mv
But since the new battery had been fitted it went away for 6 weeks ish but started again this week, i eventually tracked it down to the Ultragauge, after around 10 days the battery would have dropped to 11.9v
Anyone else had this issue? i suppose the only way to stop it is to add a switch inline, but it think that would be a job in itself! 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #840231 28th Jun 2020 1:36pm
Bluest
I think that the OBD port is permanently live. Certainly it powers my Nanocom.l up with the ignition off. If the Ultragauge draws it power from there it could well be a constant drain. 2007 110 TDCi Station Wagon XS
Post #840244 28th Jun 2020 2:51pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Yes pretty certain my UG would drain the battery in a couple of weeks.
Post #840314 28th Jun 2020 8:12pm
Roy5695
does your ultraguage stay on when you have turned the engine off??
You can adjust the start up/shut off voltage of the UG in its settings. I have never had any problems with mine and have had it fitted for several years. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #841209 1st Jul 2020 11:42pm
bear100
No it shuts down fine and works great, it just draws to much power lately, it never used too though.
And only works with the ignition on.
Interesting! I will have to look through the instructions Exclamation 2023 Defender L663 V8
Post #841217 2nd Jul 2020 5:56am
Roy5695
Mine is set quite high so only turns on when the engine is on (alternator numbing) and off when engine off. So below 13V 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #841277 2nd Jul 2020 12:15pm
