Home > Maintenance & Modifications > Penman
Page 1 of 6 123456>
DOOFER
Penman
Any of you guys run with a penman trailer on the back of their 90. I’m looking for one but as they are all so far away I’d just like to get your thoughts before I travel DON'T PANIC
Post #825322 14th Apr 2020 8:24pm
Mdm
behind my old 110
but fine behind a 90 as well
great trls
Post #825331 14th Apr 2020 8:46pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Excellent trailer, towed them for many miles over all terrain Thumbs Up I’ve only towed with a Wolf so the NATO hutch being higher on the crossmember than a civilian tow bar, must admit I’ve been toying with the idea of one for a while. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #825367 14th Apr 2020 9:57pm
Matt110
Are they the same width as a defender or wider? Can't make it out from the photo.
Post #825998 17th Apr 2020 3:01pm
Yes. The wheel track is the same, too, as like the Sankeys before them they were designed to be towed by Land Rovers. Darren
Post #826004 17th Apr 2020 3:48pm
Devon-Rover
Great bit of kit Thumbs Up
Tows nicely, follows the landy well and does offroad too. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #826025 17th Apr 2020 5:37pm
Thon
Mine (for sale too):-
Tows brilliantly, reversing is a learned art, as robust as a tank Very Happy
110 has standard springs, 7.50 x 16 tyres and hitch directly mounted onto the crossmember (using the usual backing plate now). They seem to tow nose-down on Wolf Defenders too - presumably by design.
Post #826057 17th Apr 2020 8:01pm
^^^ Lovely. Cool 110 too, wish I'd fitted a camel cage to mine instead of a full external.
Post #826087 17th Apr 2020 9:25pm
seriesonenut
There are one or two good deals on Penman trailers out there at the moment. I was looking at how they sit behind a Defender and all have a downward slant towards the towing vehicle. The military fit the hook direct to the rear crossmember. For those of you with one do you think my set up would be too low to tow safely?
pct by Richard Holmes, on Flickr 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #841194 1st Jul 2020 11:06pm
Thon
Your hitch is mounted where most people mount them. It looks to be about 2 inches lower than mine so I don't think it will be much of a problem, particularly if you have some weight in the trailer to compress the suspension somewhat.
You also have the added benefit that you don't need to remove your spare wheel when towing.
Post #841201 1st Jul 2020 11:39pm
Mash
Your set up doesn’t look much lower so I can’t see an issue Thumbs Up
I’ll happily be corrected but I’m sure a lot tow with a similar set up. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #841202 1st Jul 2020 11:41pm
Thon
diesel_jim wrote:
....wish I'd fitted a camel cage to mine instead of a full external.
Careful what you wish for. That design is a major pain in the arse with a Puma, but nice once it's fitted though.
Post #841203 1st Jul 2020 11:42pm
Devon-Rover
In my picture above that is where I had my hitch setup. Never had a problem towing it like that. Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #841214 2nd Jul 2020 6:29am
Mdm
they are designed to tow nose down.
having used mine at speed loaded and empty without issue it doesn't seem to change how it tows if its a tad lower on the back of a 110 as long as the hitch is free to rotate.
Post #841225 2nd Jul 2020 8:34am
I don't think you'll have any problems at all with that configuration, but an alternative you could consider is simply to turn the slider plate the other way up. For a Penman the pintle will be free to rotate anyway, so you wouldn't even need to unbolt it and turn it over, and flipping the slider will raise the pintle by at least 2".
Before you throw your hands in the air and decide that I have gone barmy (after all the slider is clearly marked "top" at the top suggesting that it must be used one particular way up), this suggestion was actually made to me by the boffins a Dixon Bate back in the day when DB not only had boffins but were actually knowledgeable and helpful, ie before the last take-over (after which they have raised unhelpful uselessness to an art form).
I wouldn't want to use the slider upside-down for a heavy trailer or one with an exceptionally high nose-weight, but a Penman or Sankey is a puny trailer by trailer standards and the coupling loadings are not large.
Post #841231 2nd Jul 2020 8:56am
Page 1 of 6 123456>
