Home > General & Technical (L663) > 2020 Defender main discussion thread |
recordman Member Since: 01 Mar 2018 Location: Kent Posts: 4 |
The App they are using must have been invented by VW. That Defender did not attain 0-60mph in 6.6 secs, if you measure the length of time (on a watch or similar) it took to reach 60mph it's in the region of 10-11 secs.
29th Jun 2020 8:19am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3776 |
I just watched that, to be fair 6.6 seconds to 60 would be fairly quick in a large bus.
However timing in on a stopwatch it makes it on 10.11 seconds? which actually doesn't seem that good? 4wd, 300bhp.? I try the different models in one of my wifes car, a Mini clubman Cooper S remapped, with eco, normal, sport Driving in each mode normally there is a huge difference on how it drives, feels, accelerates. However even in Green mode if you plant your foot to the floor the computers seem say OK you want to override the setting and the little car change down a few cogs and just goes.... so maybe irrespective of mode if you kick down it will override? |
29th Jun 2020 8:59am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
The only thing that I think Eco does in the Defender is make it change to higher gears even earlier than it does in “normal” - TBH in a 2.3tonne brick it seems a bit pointless. It probably gets some “green points” somewhere. One trip off-road in low ratio and you can forget any “eco-ness” in any modern Land Rover product.
In my last car switching to eco meant no air con/climate control, no heated seats, no heated screens, reduced acceleration and much more vicious regenerative braking but it was a PHEV where electric range is important but I never used the function in two years, I prefer un-misted up windows and some warmth/cooling when I drive. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
29th Jun 2020 9:18am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
29th Jun 2020 2:13pm |
Mmmm... the Gladiator seemed to make it with less wheelslip.
All the videos showing any form of off road driving, albeit tyre choice may not be perfect, appear to show too much wheelspin for my liking. The idea that a locked differential is not actually locked but has various degrees of slip is not what I'd expect in the halo off road model. |
29th Jun 2020 4:35pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1437 |
Too much wheel spin and wheels lifting off the ground makes it look like hard work.
The Jeeps on the other hand, breeze through no problem, without all the unnecessary electronic assistance. |
29th Jun 2020 9:37pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1323 |
Not sure if all the Jeeps in the video will have "proper" locking front and rear diffs and front anti-roll bar disconnect, but the Gladiator should have.
I much prefer Jeep's approach on diff lock control. On or Off. Let the driver decide based on conditions and need. |
30th Jun 2020 7:09am |
At the risk of repeating myself, this setup works (skip to 1:16 if the link doesn't do it automatically): &t=76s -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
30th Jun 2020 8:10am |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 822 |
A camel wrap from New Defender mods
Click image to enlarge yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
30th Jun 2020 9:47am |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
After watching this video I was impressed. Keeping in mind this is a straight out of the box un modified vehicle.
There is a fair amount of wheel slip in several places here, however this type of terrain is extremely difficult to maintain traction. The loose dirt is like ball bearings under foot, and throw in the un evenness and it's not an easy climb at all. Especially at the 7:10 mark &feature=youtu.be&fbclid=IwAR17QWX3yFpo5ZdtVdwQoiNRjqKaDb1zJ99IoXN-zNr8Wz_0K453gY76m0E it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
30th Jun 2020 5:22pm |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1026 |
Not much air in those tyres Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
30th Jun 2020 5:29pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3420 |
That unmodified one actually has a 2” lift kit fitted
30th Jun 2020 5:34pm |
Hard to figure out what PSI he would be running there as they are a low profile tire. I would think they would be easy to pinch if you were to go too low. Normally 12-15ish would be about right, but that would be with a more traditional taller sidewall.
Closer to normal street pressure would make that run impossible. it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
30th Jun 2020 5:39pm |
I stand corrected, just saw the mention of a 2" lift in the video comments. Also he's planning on fitting 34" tires shortly.. will be interesting! it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
30th Jun 2020 6:14pm |
