![]() | Home > General & Technical (L663) > 2020 Defender main discussion thread |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2668 ![]() ![]() ![]() |
"Now available at www.atraxion.com. Two new wheels for 2020 Defender, mounted on Goodyear Wrangler 255/60R20 . We thank Land Rover Hasselt for making this video possible." -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
"This setup" is in a completely different vehicle., until we see the workshop manual and more, it will be hard to know how similar or different the systems are. It did look OK in the video, so why does it look so bad in the new Defender? |
MrEleven Member Since: 15 May 2020 Location: Glasgow Posts: 112 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge Picked up my new defender today, really happy with it. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Very nice too, first one I’ve seen with the roof rack Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Yes, but the abilities of the D4/RR/RRS are pretty much the same, if you set aside the wheelbase & ground clearance differences. I can only assume that this one did not have the rear active diff and/or that the driver did not know how to extract the max from the vehicle. I cannot stress this enough: driving a modern LR is *VERY* different from driving an old-school one. I own both, and I drive both off-road, and it STILL takes me a good 30 min or so to adjust my driving style everytime I switch vehicles. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3453 ![]() ![]() |
@ MrEleven - Looks
I too have owned both RRS/FFRR /Evoque alongside a 1996 Defender with no TC or ABS. In the modern systems a small amount of wheel spin is needed if you are using the electronic driving aids as the computers/ ECUs need to detect where the wheel/wheels with most grip are to allow the system to send the power to the right wheel/s and brake the others that are slipping.
In the days of Freelander 1 the system needed 5 full wheel rotations but now not even one full rotation is needed for the system to work. I’m sure it works better and quicker than my brain to detect which wheel is spinning. Also a locking rear diff in a modern LR product is rare except in RRS’s with the Dynamic badge where it is standard and on SVR. For me the most noticeable difference between having and not having the e-diff was that I never needed to swap my RRS’s 22” onroad biased wheels/ tyres for a foray onto the Scottish hills, it really was very effective. It would also engage onroad in standing water and in snow. I think if you watch the Chinaman’s Cut and the later video in the trees with the Jeeps the new Defender’s wheels don’t even make ¾ of a rotation of spillage same as RRS would do. Why the Jeeps don’t do it I assume is because they don’t use anything like TR2 to move, whether the Defender would do the same if the driver didn’t use any of the special programs I don’t know - it would be interesting to see what would happen if the driver just selected low box and raised the suspension to offroad height. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Just been emailed by LRCS to please try downloading the V1 app and delete the V2 and to try logging in again.
![]() The car is also booked in for the rear door window seal (oh sir we’ve had so many like that............ I suppose it’s a variation on “they’re all like that” ) but also noticed that none of the cars in the showroom or outside on display had a deformed window seal so I think LR has been quick to get dealers to check. One of the joys of being an early adopter I suppose. The roof rail tracks will be fixed but I also have asked the dealer to supply and fit a set of black rails and supply a set of crossbars as this morning I found that despite the huge size of the interior my paddle board in its waterproof bag is about 30mm too long to allow the tailgate to close...... will I be able to get away without also fitting the access ladder or can I continue to use my set of household aluminum 5 rung steps and chuck them in the boot like I used to do with the 90 - it was so much easier with the low rise Countryman ![]() 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
Me thinks the access ladder will be too hard to pass
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
This isn't going to look good on the reliability index. LR currently 36th out of 40. Maserati and Bentley at 39/40 look untouchable, Aston Martin at 38 are going bust, but good chance LR will be challenging Porsche for 37.
Seems the more expensive the marque the more reliability suffers. Best get back to making basic straight forward utility vehicles.... 1982 88" 2.25 diesel
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
Or the people that buy expensive things are the people that are too important to read the manual.
A mate of mine that works in the service centre said that it is not unheard of for FFRR owners to moan that their car now 'wont go above 30 miles an hour'. They had put it in low range and not realised or understood what they have done. The other issue they see is 'the green car light is flashing on my dash', that's Hill Decent Sir'.....'what's that? |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2222 ![]() ![]() ![]() |
Gosh, do you not have a 'chap' to undertake that for you.......
There is no exscuse for stuff like that if there is a hand book in the car. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
