Home > General & Technical (L663) > 2020 Defender main discussion thread |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17576 |
What I'm reading here about the LKA sounds positively dangerous. I certainly wouldn't be buying one of these based on what's already been posted here. LKA not being disable-able, LKA and TR settings not being retained, and an already outdated screenwash system. Completely unacceptable and would drive me nuts.
21st Jun 2020 8:43am |
According to Simon in the video, all he drilled through was adhesive tape and plastic, so clearly to bonnet is not solid. It must have holes. |
21st Jun 2020 8:45am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4736 |
Why was the driver's headlight LED lights flashing? When I was watching this every so often I could hear my self urging the driver to give it a bit of welly. But I suppose you cannot intervene with the new technology. I noticed a lot of wheel spinning to get a bit of traction. My heart went out to the following vehicle which was stopping in some odd places while the Defender found it's way. The Jeep in front seemed to have no bother but it did not look like a stock vehicle. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
21st Jun 2020 1:11pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
You don’t need to use the technology on any of LR’s modern cars with a transfer case, just leave it in highway mode, select low range and drive it like an older model without electronic programs- if you manually raise the suspension and manually set /deselect HDC (or leave it off even) and disable DSC, all the new cars can be driven without the TR and added electronic equipment that’s there to make life easy if you want. When I’m teaching folks new to Land Rovers that’s where I start, not by showing them what TR can do as it often confuses newcomers to off-road driving when they have the impression that you have to use TR all the time, you don’t and it can be much more fun not to use the driver aids.
The headlights and sidelights flashing issue is to do with the camera taking the video not the car Last edited by Tim in Scotland on 21st Jun 2020 3:16pm. Edited 1 time in total |
21st Jun 2020 1:25pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
It’s the way some LEDs react when on camera. I’m sure somebody on here will have the full explanation. |
21st Jun 2020 1:29pm |
He must have got lucky and drilled through one of the holes the trim clips into. Click image to enlarge Last edited by J77 on 21st Jun 2020 6:26pm. Edited 1 time in total |
21st Jun 2020 1:31pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
21st Jun 2020 1:40pm |
I’ve switched it off in the centre touch screen menu and it looks like the “switch’” stays off.............. until you stop and start I can see this car is going to end up with a pre-trip checklist of things to disable before starting out on even a very short trip....... Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
21st Jun 2020 4:32pm |
"One MILLION ticket requests for President @realDonaldTrump’s rally on SaturdayDouble exclamation mark" Were JLR involved in counting requests for this as well? |
21st Jun 2020 7:51pm |
But JLR don’t make you sign a disclaimer that you won’t sue them if you get the virus in a showroom! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
21st Jun 2020 10:12pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 |
a very good point Tim yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
21st Jun 2020 11:00pm |
The “Jeep” in front was a NAS soft top Land Rover 90 - you see it side /3/4 on right at the end.......... maybe that’s why it doesn’t look like a stock Jeep and did well!.............. I wasn’t sure what the white with black bonnet one that was following him, Disco1 or P38A. On other modern Land Rovers you also get an element of wheelspin while the computer works out which wheel/S to brake/ send drive to , I think it would work way faster that the human brain to detect any wheelspin with more throttle Used by a human too. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! Last edited by Tim in Scotland on 22nd Jun 2020 5:27am. Edited 5 times in total |
22nd Jun 2020 4:58am |
There appears to be two holes in the outer skin underneath where the plastic trim lines up, and two holes in the inner skin: Click image to enlarge Click image to enlarge |
22nd Jun 2020 5:15am |
Here is Matt of Car Wow on YouTube driving a110 without using the TR at all - fast forward to 5m 01sec Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
22nd Jun 2020 6:56am |
