Home > General & Technical (L663) > 2020 Defender main discussion thread
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 222 of 351 <123 ... 221222223 ... 349350351>
J77
Emergency lane keep assist can be completely switched off in the collision avoidance menu, they recommend switching it off when towing or going off road. Down side is it has to be done every time the car is restarted.
Post #838688 21st Jun 2020 8:41am
What I'm reading here about the LKA sounds positively dangerous. I certainly wouldn't be buying one of these based on what's already been posted here. LKA not being disable-able, LKA and TR settings not being retained, and an already outdated screenwash system. Completely unacceptable and would drive me nuts.
Post #838689 21st Jun 2020 8:43am
J77 wrote:
blackwolf wrote:
You have to laugh, the first thing he does is drill a hole through the bonnet to mount his GoPro!
I didn't realise the bonnet wasn't solid under the awful plastic chequer plate stuff.
As far as I’m aware it’s metal underneath the plastic.
According to Simon in the video, all he drilled through was adhesive tape and plastic, so clearly to bonnet is not solid. It must have holes.
Post #838690 21st Jun 2020 8:45am
spudfan
Ireland
Naks wrote:
for those who don't have Instagram, the video of the Defender on Chinaman's Trail is now on YouTube as well:
Why was the driver's headlight LED lights flashing?
When I was watching this every so often I could hear my self urging the driver to give it a bit of welly. But I suppose you cannot intervene with the new technology.
I noticed a lot of wheel spinning to get a bit of traction.
My heart went out to the following vehicle which was stopping in some odd places while the Defender found it's way.
The Jeep in front seemed to have no bother but it did not look like a stock vehicle. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #838724 21st Jun 2020 1:11pm
Tim in Scotland
You don’t need to use the technology on any of LR’s modern cars with a transfer case, just leave it in highway mode, select low range and drive it like an older model without electronic programs- if you manually raise the suspension and manually set /deselect HDC (or leave it off even) and disable DSC, all the new cars can be driven without the TR and added electronic equipment that’s there to make life easy if you want. When I’m teaching folks new to Land Rovers that’s where I start, not by showing them what TR can do as it often confuses newcomers to off-road driving when they have the impression that you have to use TR all the time, you don’t and it can be much more fun not to use the driver aids.
The headlights and sidelights flashing issue is to do with the camera taking the video not the car
Post #838730 21st Jun 2020 1:25pm
J77
It’s the way some LEDs react when on camera. I’m sure somebody on here will have the full explanation.
Post #838731 21st Jun 2020 1:29pm
J77
He must have got lucky and drilled through one of the holes the trim clips into.
Post #838733 21st Jun 2020 1:31pm
Naks
Post #838734 21st Jun 2020 1:40pm
Tim in Scotland
I’ve switched it off in the centre touch screen menu and it looks like the “switch’” stays off.............. until you stop and start Big Cry I can see this car is going to end up with a pre-trip checklist of things to disable before starting out on even a very short trip....... Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #838757 21st Jun 2020 4:32pm
J77 wrote:
Chugga90 wrote:
The 1 million configuration fact was generated by J77 trying to get the spec he desired in the budget he wanted? Rolling with laughter
I like to think I’ve helped a bit Laughing
"One MILLION ticket requests for President @realDonaldTrump’s rally on SaturdayDouble exclamation mark"
Were JLR involved in counting requests for this as well?
Post #838795 21st Jun 2020 7:51pm
Tim in Scotland
But JLR don’t make you sign a disclaimer that you won’t sue them if you get the virus in a showroom! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #838814 21st Jun 2020 10:12pm
zilch
Australia
a very good point Tim Thumbs Up yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #838820 21st Jun 2020 11:00pm
Tim in Scotland
The “Jeep” in front was a NAS soft top Land Rover 90 - you see it side /3/4 on right at the end.......... maybe that’s why it doesn’t look like a stock Jeep and did well!.............. I wasn’t sure what the white with black bonnet one that was following him, Disco1 or P38A. On other modern Land Rovers you also get an element of wheelspin while the computer works out which wheel/S to brake/ send drive to , I think it would work way faster that the human brain to detect any wheelspin with more throttle Used by a human too. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #838822 22nd Jun 2020 4:58am
There appears to be two holes in the outer skin underneath where the plastic trim lines up, and two holes in the inner skin:
Post #838823 22nd Jun 2020 5:15am
Tim in Scotland
Here is Matt of Car Wow on YouTube driving a110 without using the TR at all - fast forward to 5m 01sec
Post #838828 22nd Jun 2020 6:56am
This topic is locked: you cannot edit posts or make replies.  Back to top
