Home > Maintenance & Modifications > Swingaway Wheelcarrier on Pickup with Twin Ladders? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2229 |
Evening,
Does anyone have any suggestions for a swingaway carrier solution for our DCPU? We have the drop-down tailgate and a full-length rack which has the double ladders for support at the back. I had intended getting the Safari Equip swingaway as it is Galv'd, a good price and I think would work with their bumperettes that I already have fitted. Then i realised that the RH ladder will be totally in the way! I have seen a dcpu with a similar setup but using the ridiculous priced alisport carrier which i am not prepared to splash out on. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
18th Jun 2020 9:03pm |
Will the nakatanenga one work? Still not cheap though. Ray
18th Jun 2020 10:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17414 |
The Nak one costs more than the Allisport!
18th Jun 2020 11:03pm |
Isn't the usual solution to this to replace the right hand ladder with a narrower single strut? I'm sure Patriot used to offer that as an option for their DCPU set up. Darren
19th Jun 2020 7:36am |
I think this may be more bespoke: Click image to enlarge |
19th Jun 2020 9:02am |
Looks like all they’ve done is cut the leg off and welded it back in upside down and back to front. Ray
19th Jun 2020 11:48am |
That vehicle belonged to former forum member Sonic3d who is actually the person who designed what is now the Allisport swing-away wheel carrier, and from whom I bought my swing-away. He sold (I believe) the design and manufacturing rights to Allisport.
He hasn't been active in the forum for about 6 years now, which is a shame, but I think moved on from Defenders. |
19th Jun 2020 12:31pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Mine has the Patriot ladders and the Safari Equipment swingaway. The single leg ladder uses a solid aluminium 25mm section for the right-hand upright instead of the 25mm square tube on the normal ladder.
Click image to enlarge Before fitting the carrier: Click image to enlarge The foot of the right-hand ladder needed a bit of trimming to fit inside the lower carrier bracket, but nothing serious: Click image to enlarge Both ladders have been powder coated black since these photos were taken. |
19th Jun 2020 10:01pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
I’m not sure which rack you have but mine is Hannibal with the twin ladders and I have the Safari equip swing away fitted . The only issue is where to attach the bungees for the canvas !
Click image to enlarge Click image to enlarge Click image to enlarge https://www.instagram.com/hustynminepark/ |
20th Jun 2020 6:46pm |
Thanks all, that is some good info. I will so a little more research.
My rack is the Flatdog one with the full ladders so the right one will need modification to fit the carrier. I wonder if the Safari Equip carrier can be fitted with a gas strut to hold it open in the wind/on slopes? Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
20th Jun 2020 8:12pm |
