Home > Maintenance & Modifications > Swingaway Wheelcarrier on Pickup with Twin Ladders?
rallysteve
Evening,
Does anyone have any suggestions for a swingaway carrier solution for our DCPU?
We have the drop-down tailgate and a full-length rack which has the double ladders for support at the back.
I had intended getting the Safari Equip swingaway as it is Galv'd, a good price and I think would work with their bumperettes that I already have fitted. Then i realised that the RH ladder will be totally in the way!
I have seen a dcpu with a similar setup but using the ridiculous priced alisport carrier which i am not prepared to splash out on.
Cheers,
Post #838163 18th Jun 2020 9:03pm
mk1collector
Will the nakatanenga one work? Still not cheap though. Ray
My build thread
Post #838176 18th Jun 2020 10:53pm
The Nak one costs more than the Allisport! Shocked
Post #838177 18th Jun 2020 11:03pm
Isn't the usual solution to this to replace the right hand ladder with a narrower single strut? I'm sure Patriot used to offer that as an option for their DCPU set up. Darren
Post #838209 19th Jun 2020 7:36am
I think this may be more bespoke:
Post #838233 19th Jun 2020 9:02am
williamthedog
In the second picture, that looks a much better idea and stronger. It wouldn't be that hard to make either. Thumbs Up
Post #838257 19th Jun 2020 10:55am
mk1collector
Looks like all they’ve done is cut the leg off and welded it back in upside down and back to front. Ray
My build thread
Post #838264 19th Jun 2020 11:48am
That vehicle belonged to former forum member Sonic3d who is actually the person who designed what is now the Allisport swing-away wheel carrier, and from whom I bought my swing-away. He sold (I believe) the design and manufacturing rights to Allisport.
He hasn't been active in the forum for about 6 years now, which is a shame, but I think moved on from Defenders.
Post #838277 19th Jun 2020 12:31pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Mine has the Patriot ladders and the Safari Equipment swingaway. The single leg ladder uses a solid aluminium 25mm section for the right-hand upright instead of the 25mm square tube on the normal ladder.
Before fitting the carrier:
The foot of the right-hand ladder needed a bit of trimming to fit inside the lower carrier bracket, but nothing serious:
Both ladders have been powder coated black since these photos were taken.
Post #838392 19th Jun 2020 10:01pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I’m not sure which rack you have but mine is Hannibal with the twin ladders and I have the Safari equip swing away fitted . The only issue is where to attach the bungees for the canvas !
 https://www.instagram.com/hustynminepark/
Post #838565 20th Jun 2020 6:46pm
rallysteve
Thanks all, that is some good info. I will so a little more research.
My rack is the Flatdog one with the full ladders so the right one will need modification to fit the carrier. I wonder if the Safari Equip carrier can be fitted with a gas strut to hold it open in the wind/on slopes?
Post #838588 20th Jun 2020 8:12pm
