Home > Maintenance & Modifications > Fitting new botom door seals
ChrisDefender
Hi all,
This may be a silly question so appologies. I am about to replace the seals on the bottom front doors with the improved, later style ones.
Just before I start taking off the old seals, in the picture below there are 8 of the little white fixing pins already in the rubber.
Is it these alone that hold the new seal on in the holes in the door, or do I need to fix them with anything else as well? The seals are genuine LR 029309
Any help appreciated,
Post #838271 19th Jun 2020 12:16pm
ericvv
Post #838274 19th Jun 2020 12:24pm
ChrisDefender
Cheers Eric,
I just wasn't sure if I needed any other clips but that answers my question.
Just looks like I may have to drill some new holes - never keen on that!
Post #838278 19th Jun 2020 12:50pm
bankz5152
Use some silicone/RTV as well. Helps keep them on and more water/airtight Instagram @defender_ventures
Empire Tuning - Agent
Post #838289 19th Jun 2020 2:18pm
ChrisDefender
Cheers matey,
Will do!
Post #838290 19th Jun 2020 2:21pm
ericvv
Post #838310 19th Jun 2020 3:53pm
ChrisDefender
Right, this job and shopping list is getting longer by the minute Rolling with laughter
Better to get it right though. Thanks for the tips chaps.
Post #838311 19th Jun 2020 3:58pm
ChrisDefender
Thanks to all, the new seals are all on. They went into the existing holes pretty much perfectly, just a couple that needed to be re-done but a perfect fit and much better Thumbs Up
Post #839347 24th Jun 2020 10:38am
Argee
The white clips are pants, mine lasted a year or so (door threshers don't help) so I marine sikaflexed em on, no more dramas. Thumbs Up
Post #839365 24th Jun 2020 11:46am
ChrisDefender
Hi,
I'll keep an eye on them and take measures if they snap off! I did put a bit of Sikaflex in the holes beofre pusing the clips in.
Cheers!
Post #839366 24th Jun 2020 11:53am
Argee
Yeah, that's what I did, problem is when they fail it allows the seal to move and they end up getting mullered like mine are - just a word to the wise Thumbs Up
Post #839374 24th Jun 2020 1:13pm
ChrisDefender
CHeers, info appreciated Thumbs Up
Post #839375 24th Jun 2020 1:19pm
ChrisDefender
Hi,
After successfully getting the new seals on OK I took off the door cards to clean everything up inside, add more soundproofing and dinitrol the inner doors.
All that is done, all nice and clean BUT:
I have got the door card back on OK apart from I cannot get these two last rivets in, they are at each top and bottom corner and are a plastic rivet type thing.
How to do I install these correctly, I seem to remember seeing somebody hit one with a hammer, but that can't be right, do I need to install as per a normal rivet, ie with a rivet tool?
Any help appreciated before I start the other door! Confused
Post #840470 29th Jun 2020 2:04pm
If you're using new ones, stick it all the way into the hole and then give the sticking-out stem a sharp tap inwards (a hammer used sensibly does well) to snap the pin into place.
If you're reusing the old ones, the stem is free (and will have fallen out somewhere in the door when you pushed it through, so you'll either have to find it or find something to use as a pin instead - a short length of fencing wire works well). In this case, push the rivet part without the pin all the way into the hole, squeezing the legs as required, then carefully insert the pin or pin-substitute until it is flush.
An alternative if you're reusing the old ones is to use a machine screw in place of the pin, I think I used an M4x10mm pozi pan screw last time, but I can't remember the diameter for certain. Get the right size and it will screw in and stay put, and has the advantage that you can unscrew it if you need the door card off in the future.
Post #840474 29th Jun 2020 2:23pm
ChrisDefender
Hi Blackwolf,
Thank you. I have a few new ones, so I will tap them in. I didnt want to do this without advice as I don't have many so didn't want to be left without. I got a set of the other ones too but they all came off in tact, I used the proper trim removal tools so maybe that helped!
If all else fails I will get a screw!!
Once again, thank you Thumbs Up
Post #840476 29th Jun 2020 2:31pm
