Home > Maintenance & Modifications > Fitting new botom door seals
Page 2 of 2 <12
ChrisDefender
Awesome, tapped in gently with a small hammer, door card nice and solid now
Thumbs Up Thumbs Up
Post #840478 29th Jun 2020 2:39pm
No problem. The reason they need a tap is because they are moulded as one piece, with the pin attached by a weak link which needs to be snapped to push the pin in the first time. It is easy once you know how they work, but not so obvious if you don't.
Post #840480 29th Jun 2020 2:54pm
ChrisDefender
Thumbs Up Thumbs Up
Post #840487 29th Jun 2020 3:46pm
donmacn
You're happily sorted now, but just as a thought for others who might wander along. I did this recently and for these corners I used M5 stainless rivnuts, and black socket-head machine screws.
Of course you need a rivnut setter, but once you have one of those you'll find all sorts of uses for it. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #840511 29th Jun 2020 5:47pm
ChrisDefender
Good to know though, things don't always go to plan as I am fast finding out. Had to order a new escutcheon bezel for the window winder, I broke it trying to get the damn thing back on! They are fiddly Sad Other than that all seemd to go OK!
Post #840514 29th Jun 2020 5:52pm
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Had one a few years and use it for all sorts of things that normally would be a bodge.... @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #840521 29th Jun 2020 6:23pm
Page 2 of 2 <12
