Home > Td5 > Brake question TD5 Defender |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 942 |
Normal 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
16th Jun 2020 11:35pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2185 |
Will happen on any car.
Hard to explain in proper terms. Basically "priming" the system and filling everything quickly then adding more fore it falls back. Imagine a bucket with a hole in it. Slowly poor water in and the water will slowly flow out. Quickly tip buckets in and it will stay full for a short period. Im sure someone else can explain it properly Instagram @defender_ventures Empire Tuning - Agent |
17th Jun 2020 5:31am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2865 |
OK thanks that’s one thing l don’t have to do then.
I have since searched online and found other people asking about the same thing back when the vehicles were new! |
17th Jun 2020 8:43am |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 790 |
My Td5 has ABS and I have always thought the Brake pedal is less positive than non ABS versions,
As you say, the brakes are definitely there but they do need a firmer shove than non ABS in my experience. Regards Chris |
17th Jun 2020 9:04pm |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
Check all of your wheel bearings. Excessive 'pump up' to get the bite point right can sometimes be the first pump centring the disc in the caliper, taking up slack in the bearing, second pump is normal aligned engagement.
Last time I ignored this I got home in my off road hack with a bearing that had an inner race friction welded to the stub shaft and the caliper in flames. Insta: @thebenjordan4x4 |
18th Jun 2020 10:11am |
