Home > Maintenance & Modifications > The dreaded manifold. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1218 |
Pictures might be worthwhile - can you weld a nut on what remains of the stud? Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
16th Jun 2020 4:09pm |
Kris614 Member Since: 30 Nov 2018 Location: Cwmbran Posts: 14 |
Sorry I thought I didn't attach some.
16th Jun 2020 4:12pm |
Click image to enlarge |
As you can see they have snapped inside. That's was before I started to drill.
16th Jun 2020 4:13pm |
I think that's going to be a bit of a sod to sort out. Particularly with a bit left in it because that should be harder than the steel bolt.
My only thought short of taking the head off and getting it to someone with a machine shop would be can you drill out the centre carefully and then using a sharp punch knock what's left of the thread into the centre. However my suggestion would be to whip off the head and get it drilled out by someone who knows what they're doing. I've got a mate in Meidrim who could probably sort this out for you if you can get the head off. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
16th Jun 2020 6:09pm |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2408 |
Try Nick Barne at South Wales Autotech in Springvale Ind Set
hes looked after my LR's for years Or Andrew Davies Plant Services Unit L4 Park Farm Plough Road NP40AL tell em both I sent you and they'll look after you. Andrew is very communicative. 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
16th Jun 2020 6:16pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1600 |
you can get a small mag drill in there if you remove some more parts.if you cant find one you can rent them and some good drill bits are needed.
just dont drill to deep if not head off is the safest easiest way forward... |
16th Jun 2020 7:38pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
I always drill hole in broken stud, then wind IN the broken stud, then run a tap down the thread as far as you can. THEN try and wind out the broken stud. Shame I’m so far away or I’d pop over and help. I’ve done a few.
16th Jun 2020 7:53pm |
How's that going to help on an aluminium head? Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
16th Jun 2020 8:26pm |
Granted you could make a steel plate to bolt onto the other studs but I don't think that's what you meant Ed
16th Jun 2020 8:27pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
I'm glad I'm not the only one who wondered that! |
16th Jun 2020 8:40pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3750 |
Hello
I feel your pain had similar happen to me on my series..... Had to drill it out then use a tap set, Then I spoke about my issue to the garage who look after my cars and then mentioned the 'bacon saver'? No idea this type of thing was available. basically you then re thread the hole and fit this sort of spring that when you fit the bolt you can tighten up. That isn't the correct bolt in mt picture its showing the recoil part Click image to enlarge |
16th Jun 2020 9:11pm |
That’s a helicoil. Great things and can save you some times. Timesert is a better, but more costly version. Instead of helcoils on one I did, I just went up a stud size, and increased the hole dia in the manifold to suite
16th Jun 2020 9:53pm |
The head will be helicoiled anyway because putting a thread into aluminium is just a no-no because it's so soft. Ed
17th Jun 2020 6:44am |
