Home > Maintenance & Modifications > The dreaded manifold.
Kris614
Wales 2003 Defender 110 Td5 XS DCPU Keswick Green
Anyone local to Cwmbran that's fancies giving me a hand to get two studs out of my TD5 head?
Everything is off they started moving so went for a lefthanded drill bit.. They decided they didn't want to budge and snapped the bit.
So if anyone has a spare min that would be great. Or even some advice would be greatly appreciated.
Thanks
Kris
Post #837555 16th Jun 2020 4:03pm
sako243
Pictures might be worthwhile - can you weld a nut on what remains of the stud? Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #837557 16th Jun 2020 4:09pm
Kris614
Sorry I thought I didn't attach some.
Post #837559 16th Jun 2020 4:12pm
Kris614
Post #837560 16th Jun 2020 4:12pm
Kris614
As you can see they have snapped inside. That's was before I started to drill.
Post #837561 16th Jun 2020 4:13pm
sako243
I think that's going to be a bit of a sod to sort out. Particularly with a bit left in it because that should be harder than the steel bolt.
My only thought short of taking the head off and getting it to someone with a machine shop would be can you drill out the centre carefully and then using a sharp punch knock what's left of the thread into the centre.
However my suggestion would be to whip off the head and get it drilled out by someone who knows what they're doing. I've got a mate in Meidrim who could probably sort this out for you if you can get the head off. Ed
Post #837596 16th Jun 2020 6:09pm
Welshsurferdude
Wales
Try Nick Barne at South Wales Autotech in Springvale Ind Set
hes looked after my LR's for years
Or Andrew Davies Plant Services
Unit L4
Park Farm
Plough Road
NP40AL
tell em both I sent you and they'll look after you.
Andrew is very communicative. 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #837597 16th Jun 2020 6:16pm
Mdm
you can get a small mag drill in there if you remove some more parts.if you cant find one you can rent them and some good drill bits are needed.
just dont drill to deep
if not head off is the safest easiest way forward...
Post #837623 16th Jun 2020 7:38pm
landy andy
I always drill hole in broken stud, then wind IN the broken stud, then run a tap down the thread as far as you can. THEN try and wind out the broken stud. Shame I’m so far away or I’d pop over and help. I’ve done a few.
Post #837625 16th Jun 2020 7:53pm
sako243
How's that going to help on an aluminium head? Wink Ed
Post #837638 16th Jun 2020 8:26pm
sako243
Granted you could make a steel plate to bolt onto the other studs but I don't think that's what you meant Whistle Ed
Post #837641 16th Jun 2020 8:27pm
I'm glad I'm not the only one who wondered that!
Post #837651 16th Jun 2020 8:40pm
Stacey007
Hello
I feel your pain had similar happen to me on my series..... Had to drill it out then use a tap set,
Then I spoke about my issue to the garage who look after my cars and then mentioned the 'bacon saver'?
No idea this type of thing was available. basically you then re thread the hole and fit this sort of spring that when you fit the bolt you can tighten up.
That isn't the correct bolt in mt picture its showing the recoil part
Post #837662 16th Jun 2020 9:11pm
landy andy
That’s a helicoil. Great things and can save you some times. Timesert is a better, but more costly version. Instead of helcoils on one I did, I just went up a stud size, and increased the hole dia in the manifold to suite
Post #837675 16th Jun 2020 9:53pm
sako243
The head will be helicoiled anyway because putting a thread into aluminium is just a no-no because it's so soft. Ed
Post #837713 17th Jun 2020 6:44am
