Home > Maintenance & Modifications > Optimill QR centre horn push |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
To all of you who have a Optimill QR hub, and want to get the Land Rover horn push back....
Click image to enlarge Here is a solution Go here. https://www.nakatanenga.de/zubehoer/innena...ender?c=13 Then go get one of these Click image to enlarge Click image to enlarge Click image to enlarge Lastly, go get 6 x M6 x 20mm counter sunk bolts, or button head, thread pitch is .8 if you need it The only issue is the surround has a slight 3mm lip, see picture 2 of the centre ring, which if removed, would allow the stitching to appear in the horn centre, but that requires a lathe... Tried and tested, and works just fine. Cheers Mark |
13th Jun 2020 11:46am |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
Fitted this wheel today to my 110 , so good info thanks
Click image to enlarge |
13th Jun 2020 4:58pm |
13th Jun 2020 5:10pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17378 |
My horn push is on the stalk. You have one in the centre?
13th Jun 2020 7:11pm |
No, they are called a horn push, because most cars have them there, yes, mine is still on the stalk too
13th Jun 2020 9:14pm |
I’ll give it a mis at that price
14th Jun 2020 8:35am |
Very few cars have a horn on the indicator stick! Actually think it’s law now in the US for new cars.
14th Jun 2020 9:04am |
Pay as your money, take your choice. |
Indeed, it's one of the reasons why I usually squirt the windscreen in cars other than my Defender! It was normal on the crappier British cars of the '60s and '70s but only our much-loved Defenders kept the tradition alive. I think it was usually done to avoid the need for slip rings or a hollow shaft on the column. |
14th Jun 2020 9:15am |
And most British cars used the same steering columns for years, which never had the horns in the centre.... think the Mini was one of the first to in the centre. Some had the horn press on the floor....
14th Jun 2020 10:49am |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3287 |
In Italian cities the horn is applied by the brake pedal. Or so it would seem. WARNING.
This post may contain sarcasm. |
14th Jun 2020 11:15am |
