Home > Maintenance & Modifications > Optimill QR centre horn push
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
To all of you who have a Optimill QR hub, and want to get the Land Rover horn push back....
Here is a solution
Go here. https://www.nakatanenga.de/zubehoer/innena...ender?c=13
Then go get one of these
Lastly, go get 6 x M6 x 20mm counter sunk bolts, or button head, thread pitch is .8 if you need it
The only issue is the surround has a slight 3mm lip, see picture 2 of the centre ring, which if removed, would allow the stitching to appear in the horn centre, but that requires a lathe...
Tried and tested, and works just fine.
Mark
Post #836976 13th Jun 2020 11:46am
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Fitted this wheel today to my 110 , so good info thanks Thumbs Up
Post #837002 13th Jun 2020 4:58pm
2010Blackdefender90
Thumbs Up
Post #837007 13th Jun 2020 5:10pm
My horn push is on the stalk. You have one in the centre?
Post #837022 13th Jun 2020 7:11pm
2010Blackdefender90
No, they are called a horn push, because most cars have them there, yes, mine is still on the stalk too
Post #837051 13th Jun 2020 9:14pm
stew 46
I’ll give it a mis at that price Shocked
Post #837090 14th Jun 2020 8:35am
Ah, when is a horn push not a horn push ?
... When it doesn't push and isn't connected to a horn! Rolling with laughter
Post #837094 14th Jun 2020 8:54am
2010Blackdefender90
Very few cars have a horn on the indicator stick! Actually think it’s law now in the US for new cars.
Post #837095 14th Jun 2020 9:04am
2010Blackdefender90
Pay as your money, take your choice.
Post #837096 14th Jun 2020 9:04am
Indeed, it's one of the reasons why I usually squirt the windscreen in cars other than my Defender! It was normal on the crappier British cars of the '60s and '70s but only our much-loved Defenders kept the tradition alive. I think it was usually done to avoid the need for slip rings or a hollow shaft on the column.
Post #837097 14th Jun 2020 9:15am
2010Blackdefender90
And most British cars used the same steering columns for years, which never had the horns in the centre.... think the Mini was one of the first to in the centre. Some had the horn press on the floor....
Post #837111 14th Jun 2020 10:49am
Zed
In Italian cities the horn is applied by the brake pedal. Or so it would seem. WARNING.
Post #837113 14th Jun 2020 11:15am
