Home > Maintenance & Modifications > How to fix rattling sliding windows on 90/110 |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4729 |
Found this on YouTube. Seems easy enough. Let me know if it works!
1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
27th May 2020 3:51pm |
27th May 2020 5:24pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
I did mine and used the Garrison Outfitters kit, Cured the rattle. Still leak. 1999 Defender TD5 110
27th May 2020 8:52pm |
QuintinC Member Since: 06 Apr 2019 Location: Knysna Posts: 28 |
Done that, now it seems that the fixed rear part is rattling. Anyone else have that?
6th Jun 2020 5:48pm |
6th Jun 2020 5:49pm |
Completed this today with my daughter. Very easily done once you watch the video first. I bought three strips from Paddocks but you only need two full ones and two little add ons about three inches each. Big difference in the new felt and the remains of the old existing felt. Went for a test drive and all seems well. 1982 88" 2.25 diesel
10th Jun 2020 6:01pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
This is a much better solution to the felt:
https://www.woolies-trim.co.uk/product/1649/small-window-channel Very easy to fit without removing the glass. |
10th Jun 2020 6:50pm |
The glass does not have to be removed to put in the new felt. 1982 88" 2.25 diesel
10th Jun 2020 7:12pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 632 |
I have used this channel on a couple of Puma 90s and also Wolf doortops with good effect. |
10th Jun 2020 7:37pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 793 |
99p rubber door stop wedge.
sorted. |
10th Jun 2020 8:33pm |
ashfordsv Member Since: 13 Mar 2009 Location: Wicklow Posts: 82 |
I used black cable ties, I just cut off the heads and then jammed the ties into the top and bottom window gaps, works great
11th Jun 2020 6:09pm |
I did the cable tie thing as an interim stop rattling fix. But I wanted my daughter to be able to open and close the windows so we did the felt fix. Does not take long and it is easy to do. 1982 88" 2.25 diesel
11th Jun 2020 7:36pm |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 |
What's the best way to get the new felt to go around the corner of the windows?? |
11th Jun 2020 8:04pm |
You just make a "v" with the felt and feed it into the channel . It is all in the video and it is very easy to do. 1982 88" 2.25 diesel
11th Jun 2020 8:19pm |
