Home > Off Topic > My RRC project |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4792 |
Thank you Green Machine
I must say, it does feel great to think that I've rescued it from a rusty demise and now it's looking and going as well as it did before it was decommissioned. Interestingly, my dad had lost interest in it before it was layed up. Now its looking good and driving well, his interest has been piqued - which is great to see as he's normally not particularly interested in 4 wheels (being more of a 2 wheel enthusiast). The sound with the new exhaust system is absolutely fantastic - which is even worse for fuel consumption Unfortunately it's one of those things that doesn't come across well on video. It's definitely a windows down at every opportunity kinda vehicle now! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
10th May 2020 8:19am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
Especially if you go down a road with houses down each side of it
Great work there George, can't wait for you to start the 110 On a side note, do you charge for teaching how to polish your vehicle Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
15th May 2020 8:11pm |
Sorry Procta, missed that question. The defender is just on our NFU mutual policy It's sounds lovely coming out of the far side of Ilfracombe High Street, tall buildings and an incline Vehicle polishing lessons are free. Tip polishing lessons however........ 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
15th May 2020 9:31pm |
Clayton.
15th May 2020 9:59pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5219 |
Does V8 rubble when its warming up, as you go down the box? My rover metro gta 16v 1.8 vvc used to do this with the Standard GTI exhaust. When it was still warming up, a few people were like Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
15th May 2020 11:22pm |
Yeah it has a nice gurgle when it changes down, especially just as you start to come back on the throttle 2002 90 Td5 Station Wagon
16th May 2020 8:57am |
what air filter are you using on this? i used a ITG panel filter on my rover metro, but that had the maf built into the ECU Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
16th May 2020 10:19pm |
It was on an itg filter, but now it's on a K&N ad the filter material on the ITG started to degrade, didn't want that being sucked into the engine 2002 90 Td5 Station Wagon
17th May 2020 6:47am |
Well, I've got a new pair of tips to polish!
Decided on plain 3 inch tube out of the silencers for a slightly more understated look. Obviously they will need polishing, but look OK for now Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
24th May 2020 2:48pm |
Also, I forgot to mention, the first tank of fuel with the new exhaust system came in at a frankly astonishing 14.7 MPG
Previously I have been averaging around 12 - maybe with some intake mods and eventually a different ECU/Injectors/EDIS then I might even see dreamland figures in the high teens 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
24th May 2020 2:54pm |
Taken the Range Rover for a spin today, all ok apart from a misfire at 4500 ish rpm. I'm guessing it's coil or dizzy related as it happens on petrol or LPG.
Magnecor leads (2 years old) Dizzy cap and rotor arm replaced with genuine Lucas at the same time NGK spark plugs all correctly gapped and also replaced at the same time. So basically the whole ignition system is less than 3000 miles and 2 years old apart from the distributor (which is original) and the coil (probably not original but certainly not new) My gut feeling is coil, so I'm going to replace that with a Bosch one and go from there Pic from today's outing Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th May 2020 5:59pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
Great pic George and great work on the RR 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
26th May 2020 6:36pm |
Thanks Simon 2002 90 Td5 Station Wagon
26th May 2020 6:59pm |
Yeah that will be the coil, see what the best injection system is, and also look at after market ECU stuff, even look at head work and a cam, but see if you gain anything mind. If its anything like the K series engine, you spend megger money and you gain say 5 hp, then forget it Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
26th May 2020 9:03pm |
