Home > Off Topic > My RRC project
Page 47 of 53 <123 ... 464748 ... 515253>
grafty99
Range Rover update.
I taxed it at the start of the month and have been out in it a couple of times for essential shopping. What a beast! Measured 0-60 is 7.5 seconds Shocked
Today I spent the day flatting and machine polishing the paint. It's come up pretty well, especially considering the whole paint job (including consumables) cost less than £500 Mr. Green
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #830149 9th May 2020 8:52pm
JOW240725
Looks awesome! Love that last photo. James
Instagram @suffolk_rovers
Post #830154 9th May 2020 8:55pm
grafty99
Thanks James Bow down 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #830158 9th May 2020 9:07pm
Sulisuli
Quality work as ever George Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #830162 9th May 2020 9:38pm
grafty99
Cheers Simon, I still might bring it to the next meeting Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #830169 9th May 2020 10:45pm
Procta
grafty99 wrote:
Range Rover update.
Looking great there! that's quick for the weight of the motor, Did it spin the wheels on you? Whistle
how much does it cost to insure it? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #830170 9th May 2020 11:18pm
grafty99
It does scrabble for grip off the mark yes Laughing
Classic insurance so about £160 this year I think. Defender renewal came through at £240 this year Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #830172 9th May 2020 11:39pm
Procta
is your defender insurance through a classic insurance too? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #830174 10th May 2020 12:14am
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
That really is beautiful and a real credit to you, it just shows what can be done with preparation, time and skill, you should be very proud of that Cool Thumbs Up cheers Paul
Post #830182 10th May 2020 7:01am
Co1
George: I’ve got a panel to flat off and polish after rattle can and clear coat. I’m a bit nervous about it!! Can you give me a bit of a run down of the process you used? I’m especially worried about burning through the paint on the radius at the top of the outer wing.
Post #830184 10th May 2020 7:11am
VVS210
grafty99 wrote:
Looks like you really need to turn your attention to the 110 next as it's looking a little neglected next to the other two Whistle
Post #830191 10th May 2020 8:42am
grafty99
Thank you, Paul Bow down
Col, it's pretty simple but you will have to be careful with aerosol as you have much less material to work with.
Plain water in a trigger spray bottle and 2000 grit wet and dry (I like Indasa products). Then with copious amounts of water, lightly sand the surface.
Three tips at this point ;
1) As your hand is on the panel, rub perpendicular to your fingers to avoid trenching.
2) Listen to sound it's making. If you can hear a gritty squeal, stop and wash the panel and abrasive with the trigger spray to remove the grit and stop deep scratches.
3) Keep everything very wet, if it's difficult to sand then it's too dry.
When you have a uniform surface as the panel is dried then you're ready to polish.
For this I use Farécla G3. This is where I'm afraid equipment does make a difference - ideally (and especially for aerosol) you want a speed variable polishing mop.
On it's lowest speed you want to slowly and with little pressure move across the panel. As long as you keep the mop head moving, the radius shouldn't be a problem. Edges are where you can burn through rapidly.
Polish the whole area for about a minute and then feel the panel. If it's starting to warm up then stop for a minute and continue. This is where it gets tricky as it's partially down to experience.
Once the cutting compound has broken down, you should be able to see the panels gloss underneath. At this point, with a clean cloth, you can buff the panel clean and inspect for any remaining flatting marks.
With experience you should be able to know how much more work a panel will need with the mop to remove the remaining marks. The problem is that with aerosol it's an EXTREMELY fine line between gloss and polished through.
If you can, I would sand with 1500 grit and put another layer or two of lacquer on it if possible. This will give you more thickness to work with and will, in itself, improve the finish Thumbs Up
I hope I haven't rambled on too long Embarassed 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #830192 10th May 2020 8:52am
grafty99
VVS210 wrote:
Yes the 110 is the next on the list!
It's going to have a full body rebuild, so new doors, interior refresh and an obligatory £500 respray Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #830193 10th May 2020 8:55am
Co1
If you can, I would sand with 1500 grit and put another layer of lacquer on it if possible. This will give you more thickness to work with and will, in itself, improve the finish Thumbs Up
That’s awesome George, much appreciated.
Post #830194 10th May 2020 8:58am
grafty99
No worries Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #830196 10th May 2020 8:59am
