Lower Passenger door hinge need replacing, is this correct
Hello
Noticed the passenger door drops slightly as you open it, I guess it needs a new hinge,
As Far as I can tell its just the one, the bottom one,
Is this the correct item?
Guess I would need to etch prim it and spray it, other than that is it an easy swap.
Thanks
21st May 2020 11:33am
Yes, that's the correct item, albeit a pattern part.
Swapping is relatively easy but trickier than the top, the fixings for which can be more easily reached with the window open. You may need to persevere to get the door alignment correct again but it's not complicated.Darren
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
