Home > Maintenance & Modifications > Lower Passenger door hinge need replacing, is this correct
Stacey007
Hello
Noticed the passenger door drops slightly as you open it, I guess it needs a new hinge,
As Far as I can tell its just the one, the bottom one,
Is this the correct item?
Guess I would need to etch prim it and spray it, other than that is it an easy swap.
Thanks
Post #832349 21st May 2020 10:33am
Yes, that's the correct item, albeit a pattern part.
Swapping is relatively easy but trickier than the top, the fixings for which can be more easily reached with the window open. You may need to persevere to get the door alignment correct again but it's not complicated. Darren
Post #832351 21st May 2020 10:44am
