Home > Puma (Tdci) > clunking gear change and lots of other issues |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2410 |
No worries. The clutch system sucks in some Pumas (tell me!). It is not as nice as in a permanent MB or Jap and requires a bit of "training" to deal with it. When the front (mainly) prop is damaged (eg. by loosing the greasing nipples, flanges etc) and does not turn "freely" then all the backlash is transmitted to the friction plate, etc and you get all clunks. Anyway, yours sounds like kaput. Do not accept nonsense excuses from the dealer. Puma 110" SW
5th Aug 2011 6:01am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
does anyone get or know what causes a knocking noise when rolling in neutral at low speeds, goes away in gear DEFENDER 90 TDCI XS,
7th Aug 2011 5:48am |
Perhaps a sized UJ? Puma 110" SW
7th Aug 2011 12:34pm |
camrad Member Since: 11 Aug 2011 Location: Johannesburg South Africa Posts: 1 |
I once traced the problem in my series iii to a handbrake shoe that was touching ever so slightly which made the knocking noice. I also have that slow konocing noise when rolling in neutral but have nit checked had brake yet |
11th Aug 2011 4:29pm |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
As above. Handbrake and UJs are favourites.
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
11th Aug 2011 10:33pm |
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 |
It took the dealership four days to remove the transmission and find the problem. It wasn't the clutch but the output shaft that goes between the gearbox and transfer box. Replacement part approx 60 pounds. One problem part isn't available locally at dealers, spare parts shops or LR UK. Dealership said minimum waiting period one month Only solution is an independent that swapped out brand new manuals into autos for the dealers. New transmission costs 930 pounds. Bonus is no extra charge for labour if I fit in an exhaust system and clutch so total cost: 1.5k Guess I'm broke again 2012 Fuji White 110 Flattened
12th Aug 2011 12:47am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17334 |
It seems to be a fairly common effect with the GFT MT82 gearbox. The effect is (probably) caused by the oil thinning as it heats up (unless it is the box expanding), and most TDCi Defenders seem to have a "better" and less clunky gearchange when cold than hot. Ford has experimented with thicker oils (in other applications of the MT82 such as the Mustang) but apparently these caused other problems. So it seems, for now at any rate we'll have to live with a clunky change when hot. I would suggest however that anyone with an original style (and by now rattly) clutch gets it replaced with the latest type. I have just had this done on my '07 DC and the difference it made is almost unbelievable, it is so much better. |
12th Aug 2011 8:39am |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 |
Ditto Blackwolf,
Had my clutch replaced this week and the changes are clunk free now. 2008 110 XS CSW Stornoway Grey |
12th Aug 2011 9:31pm |
shrekman Member Since: 11 Aug 2011 Location: worcestershire Posts: 20 |
The main difference between Defender and T5 is that the Defender team work with interest in what they do, it is hand built by guys and girls- some of whom have 30 or 40 years service on the same job !! T5 on the other hand is rushed through production, with - dare i say cheap quality parts that are only designed to last 3 or 4 years ..... by people who have no interest whatsoever in what they do or what the end result actually is. You will never see the true Solihull on a 'factory tour' . Defender team is around 300 heads in assembly, T5 is around 1300 !!! I'm not having a go ... but writing that it is 'cobbled' together is insulting to the workers who build Defenders. the parts have changed but the engineering hasn't. It will be a very sad day when the last one rolls past my work station !!!!!!!!!! spent 20 years fixing them ... the dealers just wont listen !!!! |
3rd Nov 2011 7:42pm |
TRR Motorsport Member Since: 07 Oct 2010 Location: Leicestershire Posts: 115 |
They may not be cobbled together but the build quality on my 2010 90 is worse than my 2005 110 and thats down to the people that assemble them. (I had to reset the passenger door the day i picked it up!)
The component quality is also worse, corroding parts, weld spatter on the chassis, failed L.E.P bulb holders to name a few and thats purely down to value engineering by JLR! "If it ain't sideways, you just ain't tryin'! |
3rd Nov 2011 9:24pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2634 |
horse manure! One only need to put a brand new Defender on a lift to see the shoddy workmanship and poor build quality. A full 18 months after we got ours, the local stealer found out that the bolts securing the top frame to the bottom frames had not even been tightened, some of them even lacking the nuts. So yes, cobbled together it is. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th Nov 2011 5:18am |
With a bit of thought to the last post, would it not be more of an issue with PDI checks at the stealers who, traditionally were allways responsible to "double check" so to say the vehicle before it is handed to the customer. This action when it worked, made sure the vehicles were in A1 condition when the owner drove the vehicle off the forecourt, any problems were reported back to the manufacturer to action any changes to quality control and gave Joe Public faith in the quality of the product they were buying.
Personally I do think that the stealers should be more responsible for making sure that what they are selling has been fully checked over, for Christs sake it's probably the one and only time that they can look over the motor without getting their hands too dirty |
4th Nov 2011 7:56am |
Even if the stealers did look over the cars, cracks that might not leak or be seen by the customer would probably be ignored to save them work and keep the customer "production line" moving "Managing quality" these days means managing it down to the minimum level the customer will put up with and remember the parts are now made in China Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Nov 2011 8:23am |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
I was worried about ours having had a massive list of issues (covered under warranty but it was a major battle). 2nd to 3rd is definitely notchy. Oddly, ours seems to get better once the box is warmed up though.
Agree with others here - treat it with a bit of care (don't shove it into each gear, be extra careful when it's cold, etc) and it should be okay. I'm half expecting to need a new one eventually; if I do I'll see my Indy and get an Ashcroft one. About £1500 all in. Defender 110XS SW gone... now VW California 180 4 Motion. |
4th Nov 2011 10:11am |
