Home > Maintenance & Modifications > Whats the pressure!
bear100
Whats the pressure!
Tyre pressures Shocked
I have BFG all A/T's all round, today looking at them they seem to sag slightly
So what pressure are yours at? Haines says 28 psi front and 42 rears, which i have put up to but still that bit saggy Shocked
While on the subject what pressures are your tyres lowered to when on sand? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #831248 15th May 2020 3:19pm
landy andy
34 all round, and down to 10 on sand.
Post #831251 15th May 2020 3:49pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Same as landy andy, 34 all round Thumbs Up Cogito ergo sum
Post #831253 15th May 2020 4:10pm
34F 36R on mine, but I do tow light and carry heavy goods on occasion. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #831255 15th May 2020 4:14pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I run 30 all round on a 90 when empty or not towing, but if they were down to 28 it doesn’t make that much difference.
Up to 36 or so and they behave more like run flats!
Post #831263 15th May 2020 5:20pm
Mo Murphy
30 psi front and rear on my 90.
50 Shades of Pennine Grey
Post #831278 15th May 2020 6:53pm
UtilityTruck
Assuming 16” then the stated pressures from LR for my 2014 are 30psi front & 48psi rear(65psi rear when fully laden)
You can go lower on the rear, and in fact I do - comfort is increased substantially running at high 30s. However you can find higher speed stability to be somewhat compromised with softer rear tyres; think big steering inputs while doing 55mph+ so bear that in mind.
Of course bfg’s are not fitted by LR so the best pressures for that tyre may differ a little due to the tyre compound, side wall stiffness etc etc.
P.s. I assumed you have a 110” based on your profile/pic 2014 Keswick Utility 2.2
Post #831296 15th May 2020 9:20pm
Eduardo
Allways 35 in front, 35 in rear if not loaded or 45 if loaded. Eduardo
Post #831302 15th May 2020 9:33pm
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
I done 34psi all round in mine also Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #831310 15th May 2020 10:10pm
VVS210
Another vote for 30 all round for general use, ran mine on that for nearly 20 years using both 235 & 265 tyres with no dramas Thumbs Up
Post #831360 16th May 2020 8:30am
bear100
Quite a few different pressures there then, So 34/35 seems to be the norm not loaded and mid 40's when loaded Very Happy
Sand driving as low as 10 psi, what is the school of thought here, should the pressure be put back up at the end of the day to protect the side walls and then dropped in the morning? 2016 Range Rover Autobiography 4.4 TDV8
Post #831368 16th May 2020 9:16am
Bluest
I’m not sure where you are planning on going, but unless it’s the Middle East you aren’t likely o be running at 10 psi all day. At 10 psi you stand a real chance of cutting the sidewall on sticks and stones. That low is just for the really challenging soft sand in my view. For general sandy desert driving you are more likely to be up somewhere 15 to 18 psi and over 20 for anything that could be stony or rocky or where you can get up any kind of sustained speed. This is also dependant on the load you are carrying, tyre size etc. What’s right will come with experience.
You need to be changing your pressures to suit the conditions at the time. A convenient compressor set up and good deflator will make this much less onerous. 2007 110 TDCi Station Wagon XS
Post #831372 16th May 2020 9:28am
landy andy
You have to choose when dropping pressures what you want to do. At very low pressures you won’t want to be driving at any speed as the tyres will over heat. If you are sand driving day after day then there is no need to air up at night, just to air down in the morning. It won’t damage the tyre. You also may not want/need to go as low as 10, depending on conditions and tyres. I find that with BFG tyres that they need a fair bit of air out to even start to get the bigger foot print.
Post #831377 16th May 2020 10:33am
Jas Ardis
United Kingdom 2012 Defender 110 Puma 2.2 USW Auto Stornoway Grey
[quote="Bluest"]I’m not sure where you are planning on going, but unless it’s the Middle East you aren’t likely o be running at 10 psi all day. At 10 psi you stand a real chance of cutting the sidewall on sticks and stones. That low is just for the really challenging soft sand in my view. For general sandy desert driving you are more likely to be up somewhere 15 to 18 psi and over 20 for anything that could be stony or rocky or where you can get up any kind of sustained speed. This is also dependant on the load you are carrying, tyre size etc. What’s right will come with experience.
You need to be changing your pressures to suit the conditions at the time. A convenient compressor set up and good deflator will make this much less onerous.[/quote]
Having spent several weeks in a desert in the ME, 34 psi is fine!
Post #844785 19th Jul 2020 9:07pm
